Same problem new bulb and new batteries + everything else appears to be as new but the torch will not come on.Same problem new bulb and new batteries + everything else appears to be as new but the torch will not come on.
pull and wiggle back and forth a little --also look and check connections for corrosion --bad bulb --new battery doesnt mean free from defects recheck battery
Make sure you cleaned ALL the corrosion out of the battery cell, and also you may have a faulty On/Off button.?The battery contacts must be absolutely clean.That is my best assumption
Hello, don't bang on the mag lite. Take a four inch deck screw and screw it into the battery one a time. Once the batteries are out. Mix up some water and baking soda.paste Take the soda paste and applied inside the tube around the corrosion areas. Rense with water and paste serveral times until the inisde of the tube is cleaan. Remove all components from mag lite be starting this operation. Wipe out with clean cloth and skake until al lwater is removed. GB ....stewbison
Unscrew the lens and remove the bulb, then get a small disposable container and fill it about an inch full with WD-40, or a similar de-seizing fluid. submerge the stuck end in the fluid for a few minutes and it should come off without issue. Make sure to clean the tube completely before replacing the bulb, lens, and batteries.
I have several maglites and have used them for years. The first thing I would make sure of is that the bulb you replaced was the right one for 2 D-cell flashlights, specifically for maglites. Other bulbs won't work properly. Next I would make sure all contact points for batteries are clean. The ones you can reach on batteries,base of bulb and base cap for light can be cleaned with fine grade sand paper, emery board or steel wool. On the contact bar that runs the length of inner tube you can check where switch makes contact. If corrosion is evident you can lightly scrape with long blade screwdriver or other tool or knife. I have rarely had a bulb burn out immediatly after installation. I would check bulb again and then make sure that end cap and top assembly are threaded in place. Also try rotating beam adjusting setting back and forth several times. I'm sure it could be the switch I've just never had that problem. Hope this helps. thanks
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it. Next unscrew the top off the torch to expose the bulb. The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc. Screw the top back on and replace the spring in the base before screwing the base back on.. Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
my maglite torch will not turn on
