Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Convergence problem with TV Pojection Sony KDP65WS550
Suddenly went out of convergence. tried flash focus didn't work
tried manual convergence with the remote control and can not make the red and blue colors fit into green, only on the center of the screen on right and left the adjustment don't go any further
  • Sony Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the bconvergence problem with TV Pojection Sony KDP65WS - 69189a5.pngt fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
Colors are separated red, yellow and green so picture is blurred
lgray1010,
Try using the Flash Focus to/or manually try to dial in the convergence. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure on between $250.00 and $400.00 USD.
-Chris
Aug 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
The tv all of a sudden went out of focus and the Flash Focus will not re-set it any idea on how i can focus without expensive service call?
It looks like you have a convergence or vertical problem. if the picture is showing kind of 3 d or warped, its convergence.
Feb 22, 2010 | Sony KP-46WT500 46" Rear Projection...
Tried to use 2002 Sony TV as large monitor for webinar. Got the TV to accept signal but could never size the screen correctly. It only showed part of the computer image. Gave up on using it as large...
Symptom shows that it is convergence out chips failure that causing misaligned images on screen. Please replace convergence out chips in tv to get converge picture.
Question shows it is Sony KP-46WT500, if it is different model let me know please.
I can provide you more technical assistance if you wish to repair tv by yourself.
Thanks.
Feb 09, 2010 | Sony KP-46WT500 46" Rear Projection...
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Dec 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Red ghosts
red convergence went haywire... you need to relace I'm thinking two convergence ICs mounted on heatsink on convergence panel. replace both for usually they both blow replace any burnt resitors too, and hardest of all now you need to reconverge the whole thing.....which is a fine art.....u might be able to do it with the remote ...but u need a manual to go throught the steps really ..but not me i do em in my sleep. take it to shop unless your technical.
Aug 17, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
597 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
