Question about Canon PIXMA iP1800 InkJet Photo Printer
Only printing half a page
When printing a page, the top half comes out just fine, but the bottom half fades into nothing, almost like the printer has run out of ink, but then when I go to print another page, the top half comes out fine again. What's up?
    Problem Solver:
  • 4 Answers
Hi KaseyQT,
I noticed your problem and thought I'd contact you about it.
Have you had your printer checked by an expert? As the problem you're having may be to do with the print heads being to close to the paper when printing, this could cause the heads to over heat and be gradually drying the ink while printing or even could be a case of the print heads being to far away from the paper while you're printing.
Also, what sort of paper are you using?
If using glossy paper, have you set the printer to the correct settings? As this could have a big effect on printing, I was once using plain A4 paper but didn't realize that my old printer (Lexmark 4300+) was still set on glossy paper, it was doing the exact same thing.
Instead of re setting the settings of the printer I went to the system restore on the system tools and restored my PC to the last known best working stage (Left click on start, place mouse over All Programs, put pointer over accessories then System Tools and then L click on System Restore, this should give you the choice of either restoring your system to the last known best working point or restoring to a date on the calender provided on screen to a date you knew your pc worked properly.
If this doesn't work then try deleting your printer from your PC by going on to the Control Panel, Add or Remove Programs, left click on your printer once and chose the remove or delete option and then try re loading the disk once your system has re started and you have fully logged back on.
If this still doesn't work, I would suggest getting your printer seen to by an expert or buying a new one.
Hope the information I've given does help.
Posted on Oct 08, 2008
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
My printer only prints the top half of a page clearly. The bottom half is feint and blurry or missing altogether.
Your inks are gradually drying out. You should have them refilled or replaced. When inks begin to finish up in the cartridge, each time you print, part of ink that has settled at the bottom prints, and if the the material you are printing is sizable the bottom part will come out faint or faded out.
Good luck & God bless!
Nov 23, 2010 | HP Officejet 6310 All-In-One InkJet...
Fine line running from left to right across page but fades about half across page to nothing, if you print from memory no line, if you run origional thru adf no line, What is causing this line when...
if it is copied on long or legal size of paper are the fine lines on top to bottom or left to right? if it id from top to bottom check for the charge roller, clean an dry it with a cloth, wet with alcohol or water. if from left to right on a legal size of paper check for any vibration coming from the developing unit, like loose gears.
Mar 05, 2010 | Ricoh Aficio 450 Copier
My hp officejet 6500 will not print pdf files . A single blank page comes out but nothing else.
have scanned records into my computer via hp officejet 6500 scanning software. when i come to print i only get the top half of the document printed on the bottom half of the page - help!!!
Oct 27, 2009 | HP Officejet 6500 Wireless All-in-One...
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
Aug 12, 2009 | HP Deskjet 6980 InkJet Photo Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
140 people viewed this question
old marine
old marine
