Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima Extra WD72 Lcd display dissapearing
Hi guys can anybody help!?! On my washer dryer the display keeps dissapearing half way through a wash and does not appear for half hour + after the cycles finished, can take as much as an hour and a half, Does anybody know the reason for this and a solution for it? Would be much appreciated.
Thank you
  • 99 Answers
New display panel needed.
Posted on Oct 11, 2008
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WT965
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Aug 23, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
197 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
