Question about Sony VAIO Digital Studio PCV-RZ22G PC Desktop
Re-Loading Software Hard drive crashed. Computer store reformated and repartitioned. Thay reloaded XP Home edition but not from my recovery disk. I have computer home now and it runs fine but I can't reload my application restore programs. I would like to get some of the programs back like Giga Pocket, Giga pocket TV Tuner, and a few more. What can I do? Thanks
  • yd24doap Jan 28, 2009
    basically the same as the question. Mt computer crashed and now my giga pocket does not work
  • 749 Answers
Since they installed a generic copy of xp, there are none of the sony installed add-ons present on the computer. go here to view the available downloads for your system provided by sony, you will have to select the "EVERYTHING" tab to see the giga downloads if it does not load there.
Otherwise you will have to contact sony for a recovery disk specific to your system.
Posted on Oct 08, 2008
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
My computer crashed and i need to install windows xp home edition but don;t have the disc what can i do
You should have a system recovery disk. If you don't, then you will need a XP Home disk. As long as you have the XP installation code (usually placed on a sticker on the outside of your comptuer), you can use any XP Home disk. It's the product code that is really needed. Go borrow a CD from a friend and use your software code that is on your computer.
Mar 13, 2011 | Microsoft Windows XP Home Edition
Windows7 crashes to blue screen when installing food networks recipe manager
Hi
If your computer can still accept reinstalling the operating system, try it. Otherwise, your hard disk drive is damaged and cannot be reformated and cannot be repair but still you can purchase new hard disk.
Jan 11, 2011 | Nova Development Food Network Recipe...
Computer crashed, reloaded all software. Window xp home edition. Now speakers do not play. Did before crash. Tech says it should play. I have done all the test he recomends and still nothing. What am I...
You may need to download the software for the sound card, it is not part of the program in many recovery disks, go to the support site for your computer, Dell, HP, whatever the manufacturer is and load up software and driver downloads by the model or service tag number of your computer. Also go tot he start menu (lower left of tray) and click on "Control Panel", in the next window click on "Sounds, Speech and Audio Devices" then check to see that the volume is turned up on the sound or it is not muted.
Nov 29, 2010 | Gateway Edison Computer Speakers
When booting up my computer it goes to the error page prior to loading windows and asks what mode...regardless of choice it goes to windows logo screen and sits there and wont load...
1. check to see if your pc is compatible with the software. You didn't specify if you are reloading or installing for the first time.
2.You didn't give hard drive capacity or any information about the Pc you are loading Windows on.
You may not have enough capacity on the hard drive to load the full XP
Wndows xp requires about 2 GB of hard drive space then at least 10 GB of space for swap files and operation files.
Jun 13, 2010 | Compaq MS Windows XP Home Edition for PC
Loading xp in my machine wich had vista home premium earlier
If your hard disk crashed then it sounds like the boot partition is corrupted or gone. I'm not sure you can rescue this without some professional software or help for that matter.
Might be just as easy & cheaper to buy a new hard drive & instal from scratch. Hard drive prices have dropped significantly over the last few years & at least you'll get a warranty with the new one!
Hope this helps
Jan 03, 2009 | Microsoft Windows XP Home Edition
Winxp
You can't downoad XP.
On the back of your PC Case should be a sticker with the phone number for Systemax. Call them, answer their questions about the serial number etc. and be prepared to pay for a recovery CD/DVD for your unit. Ask for detailed instructions with the Recovery disc or call them back once you have it in hand. They are only an 800 number away.
If you can't find the phone number for your case unit build you can try this number: 800 262 6622
May 08, 2008 | Microsoft Windows XP Home Edition
Sony VAIO Digital Studio PCV-RZ22G PC Desktop Logo
361 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
