Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Craftman Garage Door Opener Mod#139.53650SRT. It closes completely then goes back up. I replaced the sensors @ the sides of the door to no avail. I have tried to adjust the up and down on the side and rear of the motor to no avail. W could it be?
  • 5 more comments
  • luwaleel Oct 08, 2008
    I have a manual, have tried followed instructions to no avail. What I need is to know what is causing door to not stay closed.
    Checked button, not sturk, working correctly!
    The button is not stuck, the light has not worked for a year!
    There is no keyboard and the remmote is not defective, when the door closes completely, I push the remote button and the door will stay down!
    I'm an electrical tech and as such, capable of following directions. I've eleiminated the forgoing possibilities and will try the adjustment you recommend. Thanks
    I have not yet found the solution however, I appreciate being guided through trobleshooting the thing. Thanks
    Top Expert:
  • Sears Master
  • 78,919 Answers
I agree with the closing resistance may be set incorrectly, all openers have a safety feature that senses if something is keeping the door from closing, this is back force, you set the sensitivity at the back of the opener motor control, it is a little dial, reduce the setting just enough to stop the door from kicking back open when it closes, I had this very same problem with my craftsman and this adjustment fixed it.
Posted on Oct 08, 2008
    President:
  • 2,712 Answers
Check for any obstruction that is preventing the door from closing completely first..
  • Swilin Sampson
    Swilin Sampson Oct 08, 2008
    Found this solution on a different site:
    Garage doors have a "resistance setting" on them so that if there is
    enough resistance on the door it will stop and return to open position.
    A newer garage door has the electric eye close to the ground so that
    any obstruction will not allow the door to close and when in motion
    will return to the open position.
    Have you checked the electric eye for spider webs, or even ice forming over the eye or receiver?
    Another problem may be that it needs to have a maintenance checkup.
    Perhaps the chain and other moving parts need grease replaced. The door
    hinges also need to be greased regularly.
    Another alternative would be to "unlock" the door and manually open and
    close it during cold weather, then "relock" it. This would be better
    than continually holding the button down and forcing the motor to run.
    Hope that helps!
  • Swilin Sampson
    Since you said you replaced the sensors, have you ensured that they are correctly aligned with each other?
    New Friend:
  • 51 Answers
The opener may not realize that the door has closed all the way. You could have a malfunctioning transmitter or wall switch that could be stuck. Also when it opens back up does the garage door opener light blink.
  • 749 Answers
Please check the button on the mounted house controll and make sure it is not stuck depressed.
    Genius:
  • 1,124 Answers
Keyboard contact. Be sure that the keypad is not stucked, Open the remote and check it out or replace the unit.
    Scholar:
  • 116 Answers
Do you have the instructions manual.
  • 3 more comments
  • mastermind10 Oct 08, 2008
    Depending on how old the opener is you should have a green light on one of the sensors that is on all the time. If you have a newer opener, this light will be orange. If you bumped the eye, then it is just out of alignment. Look to see if there is light flickering or fluttering or not on at all. To realign it simply loosen the screw attaching it to the bracket and move it until it is a solid green then retighten it. Sometimes the flickering or fluttering is so faint that you have to get on your hands and knees and look at the light.
    If the lights aren't on at all check for loose wires on the back of each photo eye. If you have the older style photoeyes ( rectangular in shape, two green lights and a bolt going all the way through them) they are natorious for having bad connections at the back. Otherwise make sure all the wires are connected at the opener head. One of the lights should be on all the time as long as the wiring is ok and the opner has power.
    Yes, It is real simple. Either you have three screws on the back of the opener or you have four plugins. Either way they are color coded. You should have two wires with a black tracer and a solid white wire. These are your photo eye wires. Then you should have a wire with a red tracer and a solid white wire, this will be your wall button. Hook the black wires up to black all the white wires up to white and red up to red.
    If your orange light is not on, then it is not getting power or it is bad. I would bet you got a loose connection somewhere though. Once you get the orange light back on fiddle with the sensors until the other one glows a solid green.
    try this simple option
    On the back of the motor unit you will find a control called the "down/close force". Adjust this just enough to get the door to close.
    Make sure about the sensors they are pointed at one another. Each of them has a small light that should be on when properly aligned.
On the sensor for the craftman garage door opener 1 is orange and the other is green and my garage door doesn't open with the remotes
Nothing wrong with the sensors. They don't work when the door is opening anyway. Only when closing. Make sure the light in the wall control is not flashing. If it is press and hold the lock button for 3 seconds.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door is a craftman . The problem is the door opens fine but won't close unless u hold the button till its completely closed. I noticed this only happens when its cold out any suggestions !!!
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftman garage door opener. I cannot close with remote. Please help me
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and nothing is blocking them. Each one has a small light that will be one when they are pointed correctly. If you can't get both lights to come on you need new sensors.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage door starts to close and then opens up
I had a simular issue, except mine was that the previous owner decided to mess with all the settings and mounts and screwed everything up.
The problem isn't your force sensors its your downwards stopping sensor on the opposite side of the opener. For me I had to take the entire panel off and replace the sensor back in its holder, but try adjusting that sensor setting (clockwise goes down, counterclockwise goes up).
If that doesn't work then i dunno:)
Also set both force settings in between 0-1, for some reason with mine if i set it higher it would set them off....
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
3.75 craftman garage door goes down a foot then immediately reverses back up
If when it does this your main light flashes 10 times it is the door sensors. Make sure they are aligned properly. If the main light doesn't flash 10 times then you most likely have a bad RPM sensor board. It is a small printed circuit board just in front of the motor.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garage opener
The blinking LED is sending the code for "RPM sensor or motor overload. It isn't the motor or it wouldn't run at all. The RPM sensor is a small printed circuit board near the front of the motor. It will be available at Sears or any good door opener service company.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener won't close completely
look on the side of the openeer usually lekt looking at it from the rear theese are your travel adjusters one turn = 2" travel normally
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
141 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
