Tried using another spare tire and the wheel still wables
I assume that the wobble is side to side and not up and down. The most benign cause of wheel wobble is a bent tire rim; but since you've tried another wheel and still get the wobble, the cause could be a bent housing, bad bearing, a number of things. In any case, if you don't get it fixed, a castastrophic failure is likely to happen. The rear axle is semi-floating; the axle and wheel are held on only by the pressed-on bearing and a small circlip. See a mechanic ASAP.
Welcome to FIxYa.com
rear of truck under neath frame
Regards, Lee Davidian
Thank you for using FixYa,com.
