Question about Pioneer Car Audio & Video
Feed back on rca's - Pioneer Car Audio & Video
  • 360 Answers
Turn down the gain on the amp......... if not get an isolator for your rca..... u could run a ground to the amp from the radio.
Posted on Oct 08, 2008
I purchase a denon AVR-591 & now i am using speakers from a kenwood home theater system but know all of the speakers work except the subwoofer does not, know the swbwoofer input has a wire Plus Minus...
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Feb 26, 2011 | Audio Players & Recorders
Need tp replace power cord how do i do that
The RCA R52wm24 most likely has a push in cord that is very similar to a computer monitor cord. Radio shack sell them over the counter. Also most TV shops will have them used and sell for a few dollars. WE do all the time.
Please leave feed back
Feb 21, 2011 | RCA R52WM24 52" HDTV Projection Television
Amp comes on but music plays for 30 seconds then crazy feed back noise.one of rca jacks feels loose are they replaceable
Yes they are can be replaced. If you meant the RCA female sockets on the amp then it needs that the amp is taken out and the RCA terminals soldered -- it can be poor joints. If not you can de-solder and change with a new one.
If this is the RCA main socket then the wire can be **** off and a new RCA jack of good quality can be soldered, taking care to keep the shield and main line with a good solder point.
Feb 05, 2011 | Phoenix Gold Tantrum 600.4 Car Audio...
Cable adapter broke off the back of my tv can this be fixed
yes depending on the damage. i repair 2 or 4 or these a month. the connector can be put back on or replaced. the connector is attached to a metal box this is the tunner the component that is used to select the channel. to repair these technicains remove this box from the curcit board and rebuild it. just depends if the tuner has been damaged. otherwise it would have to be replaced. their is one other option that can be used. You can feed the cable into a vcr and use it to change channels and feed it in using rca yellow red and white cables on another input.
Oct 18, 2010 | RCA Televison & Video
Have sound but no picture
The main problem can be the two back light inverter boards, or the main power supply problem. Look at the power supply for 24vdc feeding the inverter board first, it can also be cuased by bad main logic board not seding the signal to turn on the back lights. See where baords are located here: http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Jan 06, 2010 | RCA L26WD12 26 in. LCD TV
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Car Audio & Video Logo
41 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
