Most headsets do not come with a volume control interface but your mic can be adjusted by going to Sound and audio devices via the control panel of your start menu. The volume can be accessed through the audio tab. Also, depending on the program you are using i.e. Skype, Team Speak or other, your volume settings can also be adjusted within that program as well. Hope this helps.
The left side seems to have a faulty connection with the sound being absent or intermittent....
(More)
The left side seems to have a faulty connection with the sound being absent or intermittent. Occasionally it sounds normal. Waggling or tapping the actual ear phone seems to activate the sound but dfficult to make perfect. It is not the cable. Otherwise, I think hat they are great.
My Sony MDR-RF970RK Headphones stopped working. After fully charging them they only work for about...
(More)
My Sony MDR-RF970RK Headphones stopped working. After fully charging them they only work for about 10 minutes and then turn off. They're probably about 2 years old and I'm wondering if I might need new batteries. What type of battery does it need? How can I tell for sure if this is the problem?
My 3 week-old Sennheiser RS140 headphones stopped working. It appears as if the base station is...
(More)
My 3 week-old Sennheiser RS140 headphones stopped working. It appears as if the base station is receiving an audio signal as the on/off light and compression lights are on, however no sound is coming out of the headphones (not even the beeps). I've reset the system as described in the manual by unplugging the base station and removing the batteries, but that did not work either. I've also replaced the 3-week old batteries with brand new ones, and tried a different audio source, but still no sound. Any ideas? thanks
Right phone doesn't work. I hadn't used them in a while. After charging, the left phone is fine, but...
(More)
Right phone doesn't work. I hadn't used them in a while. After charging, the left phone is fine, but not the right.
sound from left headphone is intermittent.It has sound for about 10 minutes than cuts out. It...
(More)
sound from left headphone is intermittent.It has sound for about 10 minutes than cuts out. It eventually returns. Some times "wiggling" the noise canceling button will restore the sound.
