Question about Husqvarna Designer I
My designer 1 keeps saying "No floppy Disk Inserted" and of course there is.
First I had problems with the touch screen. I calibrated and seemed better. Now even though there is a floppy in the machine it says no disk inserted.
  • maycry Oct 19, 2008
    Thank for your help, I have come to the conclusion that I need a new floppy disc drive in my Des 1. And yes, I had tried several floppys including the ones that have come with the machine.
    I have considered doing the upgrade to the USB. May I ask, how expensive?. My des 1 is at the repair guy now. He probably will be calling in a few days to let me know exactly the situation and charges. Hummm. Thanks ahead for all your feedback.
  • 201 Answers
Do you have this problem with only one floppy, or have you tried several? Make sure the floppy is pressed into the slot fully. It should sort of "click" in.
Is the floppy properly formatted for the Designer1? You cannot just drop embroidery files onto it and put it in the machine - the designs need to be in .shv format and in a certain file hierarchy. Only genuine Husqvarna embroidery disks, or ones created in Husqvarna or Embird software can be used.
Of course it may be a sign that your Des1's floppy drive is not working, in which case you will have to take the machine in to be fixed.
Post more detail on your problem and I will try to offer more specific advice.
Pamsquilt
Posted on Oct 19, 2008
  • Pamsquilt Oct 19, 2008
    That's a shame it wasn't more easily diagnosed and fixed. Hope the repairs are not too expensive. I got my Des.1 upgraded to USB when the disk drive gave out - not cheap, but I have not regretted it. You get a new motherboard with the upgrade, so that means you start over with new equipment inside the machine.
    Pamsquilt
Recently had D1 color screen. Now I cannot load floppies or disks. I keep getting error messages. I did re calibrate the machine. Any suggestions is appreciated. Thx
Sound like your floppy disk drive has failed. However, if you have a vacum that will blow, try blowing air into the disk drive in case it has some thread or other debris in it. Good Luck!
Jan 05, 2015 | Sewing Machines
The 3-D embroidery system seems to be only compatible with downloading the designs to a floppy disk. I have a Husqvarna Designer I that has a USB port. Is there any way to download designs to an USB...
USB Designer 1s use Disk Manager, just like their floppy disk sisters, but it needs to be Disk Manager USB. New USB Des1s came with this program on a CD, and this software was also included free when a floppy disk Des1 was converted to USB. If you bought your D1 USB new, check the disks that came with it - one should be Disk Manager USB. If you purchased the machine second hand, contact the seller and ask for the program. It is a free standing program and you don't need a dongle. Check your 3D software - you might already have what you need. Open 3D, click down arrow for Accessories (far right-hand side) - what does your Disk Manager say? If it says Disk Manager USB you are okay to go.
I am not 100% sure of this, but I think that maybe the last update for 3D software (version 7.25) might have included Disk Manager USB. Go to the Husqvarna website and make sure your 3D is updated to the latest version.
If none of the above helps you, there is always the cheap cost embroidery software alternatives: Embird or Sew What. I believe they can write to Designer 1 USB sticks now.
Nov 09, 2010 | Husqvarna Viking 1
I just bought a used Designer 1 with customizing software. Customizing recognizes my external a: Floppy Drive. When I go to Disk Manager to download to a fresh floppy, Disk Manager doesn't see the...
What worked for me was to not put the disk in the drive until I was ready to write to it. Sometimes this would be enough to make Disk Manager find the disk. If it didn't, I would re-format the disk. Re-formatting seemed to force the software to go look for the disk. This worked for me because I did not store all my designs on floppies. I only used the floppy to load what I was going to be embroidering out at that time. All my designs are stored on the hard drive which is backed up regularly, and are readily accessible for writing to the media I use for my D.1.
Nov 08, 2010 | Husqvarna Designer I
Disk error
It is just one design of a menu full of designs, is that right? Try re-loading the design from your software and maybe a re-format of the floppy before writing to disk.
Apr 26, 2009 | Husqvarna Designer I
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Nov 15, 2008 | Husqvarna Designer I
General disk error reading when i insert a disk
Look at the floppy disk using Windows Explorer. You should see something to the effect of menu1, menu2, menu3 menu4 and one or two files with a file extension of something like .mhv or .phv . Inside the menu folders, you will find the .shv files.
Just writing the .vip or .hus to the floppy will not work.
Keep me posted and I'll try to come up with something more.
Oct 01, 2008 | Husqvarna Viking 1
Embroidery stick
You need to wait a minute or so after inserting the stick before touching the icon on the screen. This is my procedure, which works for me:
Machine off; put on embroidery arm; turn on machine, calibrate embroidery arm; start to hoop project, look out threads etc for a little while (the machine's internal computer is "booting up" in this time); insert USB stick (make sure it lights up); finish hooping, thread machine for first colour etc for a minute or two; touch stick/floppy icon; design menus load; continue making my selections.
If you get a message "no disk" or something like that, push the stick in tighter - but don't be too rough with it!
The sewing machine actually has a computer inside it, and it needs time to do its thing. It is unfortunate that the internal computer is a very slow one! We are such a "now" generation, it is very frustrating having to wait. I do find that if I occupy myself while I am waiting, it is not such a nuisance and I avoid the temptation to just keep jabbing at that icon until something happens.
Pam
Dec 20, 2007 | Husqvarna Viking 1
Embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Dec 18, 2007 | Husqvarna Viking 1
Sewing Machines Logo
381 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
