Question about Goodmans 289NS 14" TV
"No Signal" but aerial working ok on other tv in house!
We have a LD2050FVT Goodmans tv (20"). My son was using his playstation on it - tv worked fine before he started playing. After turning PS off, screen just displayed "No Signal" and then counts down from 5 mins and turns off. The user manual does not mention anything about "No signal". Any ideas??
  • Anonymous Dec 27, 2008
    Our main TV works fine thru freeview but every other aerial point in the house has no signal either thru a digibox or normal terrestrial tv. They did work very briefly when we moved in until we connected a PS3 up to our main TV. Any ideas?
  • 374 Answers
Your son more than likely changed the input source. You may be able to change it back by pressing the channel up/down button or you may have to enter the menu on the tv and change inputs that way. PS's will usually connect using a video input using a red/white/yellow cords. You may also want to ensure the connections are in their proper place as I do not know how savvy your son is at changing the setup over to play his PS. If you use a modulator to connect to the TV-either the PS or aerial- ensure that it is powered up also. I hope this has been of assistance to you and thanks for using Fix Ya. If I can be of further assistance let me know.
Posted on Oct 08, 2008
Why won't my tv connect to anything? Had no picture or sound, it says No Sync. Signal.
Assuming the television is OK and you have selected the correct 'SOURCE' then check you aerial connection and retune the set. If this does not work, take the set to a friends house and try in a 'known good' location. Download the user manual and use Dr Google for hints and tips to FAQ's. Cheers
Dec 14, 2016 | Televison & Video
Why does my new television keep pixcelating? I tried another television & it is fine. I have a booster on my aerial & another on the tv.
If it breaks up with large pixels it is a lack of signal but in your case it might be too strong a signal. On a new set it is unlikely you need to boost the signal. Try removing them. Also check the connections on your satellite or cable box. If you use a signal via an aerial, check for nice clean connections on the junction box at the aerial itself.
Dec 14, 2015 | Sharp Aquos Televison & Video
Hi, We have a Panasonic Viera Plasma TV. The TV was on when all of a sudden we heard a few clicking noises and then the picture was lost and a 'no signal' message was displayed. We tried other channels...
It sounds like you have taken the steps to isolate the problem to the TV. it seems to be a bad tuner on the Main board. The no signal displayed indicates the TV is otherwise okay. If you have a DVD player or other source you can connect, and you get a picture, then your TV has a bad tuner for sure.
Feb 21, 2015 | Panasonic Televison & Video
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I have just got a goodmans LD2271D HD ready digital lcd tv and for some reason it wont tune any help? i've been to the menu and selected auto tune and it still says no service.
This usually means poor signal , HAD THIS PROBLEM WITH MY MOTHER IN LAWS TV, Take tv to other aerial point in another room ( i brought mother in laws tv home to my aerial ) and do a retune,
This could sort things out.
pete
Nov 09, 2010 | Goodmans 289NS 14" TV
No TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Jan 02, 2010 | Televison & Video
Trying to install channels on goodmans ld1962d. Not sure what active antenna is. No channels are found when we have aerial in or out.
check for antena cable plug condition, normaly 80% of low quality of antena signal, is conection on antena plug (inside)
1st open antena plug, check for condition/connection of cable.
2nd check for each part of cable well connected, and no wires crossed on middle cable
3rd check same to the other end of cable.
4rd check the signal on diferent tvs around house (if available)
if this general you dont have aerial signal in your house, check for your TV provider (cable) to test your arial signal.(Normaly this maybe a cable broken outside house).
Nov 22, 2009 | Televison & Video
Hi, I am new to digital TV's. I have recently bought a 15.4 inch Goodmans Combi and it works OK at home. Last week I took the TV with me on a caravan holiday and despite using the site's booster system all...
Notthing,signal not strong enough,have block mountains,landscaps extra..Have a digital antena work better,stronger amplircation,less interferences.
Sep 09, 2009 | Televison & Video
Goodmans 289NS 14" TV Logo
677 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
