Question about Texas Instruments TI-89 Calculator
Doing Hex Calculations.
Hey, I have recently been doing many Hexadecimal calculations as part of some programming I'm doing, and I thought that the TI-89 Titanium would be a good choice of calculator for this, however, I have discovered that there are discrepencies between the actual answers, and the answer the calculator shows (namely that it only shows the final 8 bytes of any answer).
For Example:
[1A56B091] x [41C64E6D] = [6C469F301DB5BBD]
However the Calculator shows:
[1A56B091] x [41C64E6D] = [1DB5BBD]
I was wondering if there was a setting or something that I can alter in order to make the calculator display a full answer, rather than just the final 8 bytes? Any help would be greatly appreciated.
  • 360 Answers
Seems your close to hitting the limit to the actual working decimal numbers too. Because everything is terminated after that. I'd like to help you but, however you got your example number, just assimulate it to the Ti89. I'm pretty sure I could add series aiding like that by writing and running a program.
Posted on Sep 14, 2009
How to convert a dinary number to a binary number using a casio fx-82MS calculator
Dinary? Never heard that one before. What is a dinary number? Anyway your calculator cannot perform the operations. The Casios can work in Binary (base 2), Octal (base 8), Decimal (base 10) and Hexadecimal (base 16). Some Sharps can do calculations in base 5 (pental).
Feb 19, 2013 | Office Equipment & Supplies
How do i convert from decimal base to hexadecimal base?
You cannot. The calculator does not have the Base-N calculation mode. You may try find programs that perform base-N calculations on TIcalc.org.
Dec 13, 2012 | Texas Instruments TI-84 Plus Calculator
How can I reset my Casio FX-115 ES calculator to its default settings
There must be an error in what you report. You pressed MODE then 4: Base-N and now your calculator is in base-N calculation mode (the DEC, Hex, BIN, OCT) numeration keys are active.
To do statistics you must put the calculator in STATS mode.
Press MODE: You have 6 computational modes to choose from
1: COMP, the general computational mode
2:CMPLX, for calculation s with complex numbers,
3: STAT for statistics,
4: Base-N, binary, octal, decimal, and hexadecimal numeration
5: Equation, solving mode, etc..
For statistics, choose 3:STAT
Apr 24, 2012 | Casio FX-115ES Scientific Calculator
How do you do hexadecimal addition on she Sharp EL-W535HT?
Press [2nd F] [x: multiply sign] to enter Hexadecimal base calculation. The digits are 0,1, ...9, A, B, C,D,E, and F.
Enter a number in Hex, press the + sign to perform and addition or - for a subtraction. Press the = sign to obtain the result.
Feb 19, 2012 | Sharp Office Equipment & Supplies
I need to take out the HEX function to make other calculations
For the F-502, well there is no manual available to download, but I did get a picture of the calculator. I will use it and try to answer your question. to get out of the Hexadecimal numeration you should set the numeration to decimal. Press 2nd F then + .
If you happen to have the manual, why not scan it and upload the file to the FixYa site. I am sure it will come in handy when one has to answer questions.
Aug 13, 2011 | Canon F-502 Calculator
I have a Sharp Scientific calculator EL-556D (it is old - have had it for years all through uni). It has HEX on the screen and is not calculating correctly. The screen is going faint too - could it just...
If it displays HEX, then it is doing calculations in hexadecimal numeration. If that is not what you want change the numeration mode to DECimal. As to its screen being faint, then its battery may be depleted. I may be time to get a new calculator?
Jul 28, 2011 | Sharp Office Equipment & Supplies
I have an exam next week and I need to know how to convert and solve: Decimal, Binary, Octal, and Hexadecimal on my TI-30Xa. Is there a tutorial available?
I am sorry to disappoint you but this calculator does not do base conversions. Here is a link to the manual so that you can verify what I am saying. Also, look at your calculator and see if there are any keys that are marked OCT BIN HEX. If you do not find any then you can be sure that the calculator does not do base calculations.
Aug 25, 2010 | Texas Instruments TI-30XA Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Binary conversion
In the FX-300Ms manual, the same for the FX-82MS, there is no way to use base-n (binary, octal, hexadecimal) calculations.
Sorry.
Feb 22, 2009 | Casio FX-300MS Calculator
I'm trying to calculate base number equation
You are victim of a confusion between terms. Base-n calculations are calculations using various numeration systems (bases) : binary (2), octal(8) hexadecimal (16) and decimal (10). What you want is how to calculate powers, logarithms, exponentials and these have also the notion of base; Log in base 10 is the common log, whereas natural logarithms, are logarithms in base e.
Back to your exemple: 5 times 5 and raise the whole to power 3?
In that case [(] 5 [x] 5 [)] [^] 3 or [X to the 3] if you have such key or
25 [^] 3, because 5x5 = 25
5 times (5 raised to power 3)
5[x] [( ] 5 [^] 3 [)] or 5 [^] 4 because of the rules about products of powers with the same base.
Hope it helps.
Feb 17, 2009 | Casio FX-115MS Plus Calculator
Texas Instruments TI-89 Calculator Logo
81 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
