My hard disk witch is a 120 gb drive started to reboot after new xpinstall. with on line connection /
    Genius:
  • 1,124 Answers
This (reboot) is related to some drivers or hardware issue or pwer supply problem.
Start up your computer and before start loading windows hit F8 and select "safe mode"
Check there what is going on.
Posted on Oct 08, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
Reboot while Formating Hard disk Maxtor diamondmax plus 9 120 gb ata/133 hdd Now my hard disk says it's damaged when i want to format it, can you sugges me some software to repair it ?
you could runthe chkdsk utility click start tpe cmd you are now in dos then type chkdsk/f/r to scan for and attemp to repair any bad files and bad sectors on your hard drive this will schedule to happen on restart of your computer another way of running the chkdsk utility click start click to open you should see your drive C: right click on select tools check now you will see two boxes tick in both again this will schedule to happen on restart if this is your primary hard drive with your operating system on it
hope this helps you
Jul 24, 2011 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
I have a problem with Hitachi 120 GB harddrive model E5K160. I tried to connect my HDD to several systems including XP and Windows 7 and I get the alert baloon that it got malfunctioned. USB device name...
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
hope this helps
Jul 18, 2011 | Hitachi Hard Disk Travelstar E5k160 120gb...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
I have a flashing light on my Fantom hard drive light. Did it crash?
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Fantom Drives 120 GB Hard Drive
Hi I have a Fujitsu Mobile MHV2120BH 120 GB SATA Hard Drive, I want to install XP home on it. But Ive been reading that I need Sata/raid drivers for the computer to see the drive. I have a HP Pavilion...
The SATA drivers will be on the XP disk. Just put the XP disk in your CD drive, partition the new disk and load the OS.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Fujitsu Mobile MHV2120BH 120 GB SATA Hard...
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
Can't install external hard drive. Do not have disc or manual. When I connect drive to USB port, drive lights up and makes sounds, but does not show new hardware.
Most likely the drive hasn't been initialized. Go to start, right click my computer, then manage. Select disk management on the right column. A window should immediately pop up saying disk initialize wizard. Press next, and it will guide you through on how to initialize the disk. Make sure you format it as well, so that the computer will recognize it as a drive.
Dec 29, 2009 | Maxtor OneTouch III Mini Edition 120GB...
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
