Question about Lowrance GPS
I have have a new ifinderH2Oc and am looking for a chip (mmc card)that will show land detail,rivers,paved and secondary roads for hunting & snowmobile purposes in northern and UP michigan. I have a Navionics HotMaps premium but is lacking in the detail I'm looking for.If such a card is available where may I purchase one ?? ****
  • knotenuff2 May 11, 2010
    I didn't want to purchase one of your advise plans, I simply wanted to purchase one of your products if available !!!!! Does anyone read these requests if they are not paid for ? How about a phone number so that I may talk to a rep. that knows your products. I have yet to find one !!
I went to a reliable source & did not have to pay !!!!
Posted on Oct 20, 2008
How do I get my Garmin 1350 gps to take the highways not the back roads. Have tried it on "shortest distance" and "fastest" doesn't work either way
Setting the Avoidances to Enabled and checking off the box beside the Unpaved Roads should avoid most back roads unless the back roads are paved.
Setting the GPS Route Preference to the Faster Time will usually route via the highways unless it is actually faster to take the secondary roads.
In any case it is usually a good idea after creating the route to view the map and have familiarize yourself with the route. Via points can then be added to modify the route as necessary.
Sep 18, 2011 | Garmin Nuvi 1350/1350T 1300 1390 3790T...
What if I dont replace the inner & outer tire rods in my Land Rover? I am only driving on paved roads and what could happen if I dont replace? There is 60k miles on the vehicle. They said that L/F...
u will chew out tyres also bad steering ie wandering from left 2 right wheel bearing could colapse completetly wheel & hub could part company with vehicle specialy in a heavy vehical like a landrover really is best to get them sorted tierods connect front wheels 2 steering if they collapse you will have no steering
Sep 08, 2011 | Land Rover LR3 Cars & Trucks
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
LOST DATA
of course if it would be MMC card that the information was, you could always try to insert it to the PC with card reader and see if PC tools could be in any help
May 28, 2010 | Nokia 6600
MMC is not working in ROKR E6
click on the task bar(the place where u see the network indicator) then u will see a different screen on that the click on eject ,then remove the card and insert it again,if this does not resolve reply back
Sep 11, 2009 | Motorola Mobility ROKR E6 Smartphone
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
4WD Kicks Out While Driving
Have your transmission and transfer case checked, this could be the only parts broken on the basis of what you have told us. when you said you heard gears grinding, it is better to replace them.
In your case, I would presume that you were driving on a paved road, Engaging your 4WD on a paved road and doing 80-100km would really damage your 4WD system. wetness of a paved road is not enough to justify the use of your 4WD because there is enough traction on both front and rear tires that could cause your gears to resist each other.
It would be a different case if you drive at 80-100km on a dirt road or off road, i will assure you nothing wrong will happen.
You may still engage your 4WD on a wet paved road but do only a 60 or below.
Nov 20, 2008 | 1994 Jeep Grand Cherokee
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN (sajwhat_2003@yahoo.com)
May 05, 2008 | Motorola Mobility RAZR V3
GPS Logo
128 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
