Question about Samsung DLP HL-P5663W 56" TV
SP50L7HX/XXEU hi i was reading your post regarding the above model dlp tv,is it possible to send me the site were i may be able to find help and faults for my tv please,the tv goes straight on to standbye on switch on thanks for your help ,bobmy email address is nicynic@btinternet.com
  • Maryann Young
    Maryann Young Apr 20, 2009
    same thing happening to mine am ready to bin it
  • 905 Answers
You can get it here! for your tv just unplug it for a while at least a day you can try before but you should wait then plug back in and see if that helps if not then it is a electronic issue and will need repair
Posted on Oct 10, 2008
I have problems with my tv set its model is specific i dont know which type of model is this but it is flat screen tv. it shows red, blue and green line merged into one another in the centre of the sc
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line faults to LCD screen is given with illustration, and possible fault location.
Jul 28, 2014 | Mitsubishi DIGITAL ELECTRONICS XD250U DLP...
Hello FiXYa team! i spoke with samsung company regarding the problem with my tv clicks but will not start. they said my tv samsung plasma model HPT-4254X/XAA does not fall in the category of the tv
Just visit this site named 'Electro-help', and refer it. You might get details about the problem you faces with your plasma TV. Generally all plasma TVs will have general structure in circuit and fault descriptions. Click this link and select the site named above. Pull up older posts there.
Jul 30, 2012 | Televison & Video
Blue band forming across the bottom of the screen after lamp replacement
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Prior to paying for any repair, read this regarding Sony's many problems with LCD TV's since 2004. You could get some $ back on your lamp replacement and possible help to get current problem repaired. Hope this helps.
Sep 19, 2010 | Sony KDF-42WE655 Television
I have a SP50L7HX, I have just changed the bulb
the lamp that you have replaced ;is it the same type then the original/ because that will never come on because the protection system come on right away for the reason that is grab to much current.
and avoid to touch the lamp as possible...
but if its the same ;you may have something
in the power supply/or it could be your firmware
in the bios of your tv, look the website if can find a update file for your set.. you should have usb service connector on the set...
hope that will help you
good luck
Apr 08, 2010 | Televison & Video
I have replaced the bulb but still it will not turn you can hear everything start up but it seems as not enough power to light the bulb help please I have a samsung DLP SP50L7HX it still shows the bulb...
Hi,Sometimes its something simple.Did you close the door cover,it has a switch that wont let lamp power on if its not pressed.Did you reset the lamp timer? you can do this by unplugging the tv wait 5 min and plug it back again.Any strange noises like clicking or buzzing sounds? If you heard clicking it will be an issue w the board that powers the lamp its called the ballast.If you heard buzzing it could be an issue with the color wheel,which is a small disc that creates tyhe colors on your tv. Last question did you get the Original Philips lamp or a generic? If you got a generic send it back for testing or get refund and get yourself the original.Email me if you have further questions at r2d2repair@gmail.com have a blessed life!
Nov 17, 2009 | Samsung SP50L6HX 50" DLP HDTV
My samsung dlp tv sp50l7hx had to bemoved to lay
although the lamp may look ok your tv has all the signs of lamp fail they only need a slight bang. I know that it is cheaper to replace lamp than light engine
Nov 08, 2009 | Samsung SP50L6HX 50" DLP HDTV
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
On and off
I have the same problem and am looking for a fix too. Have you fixed yours yet?
Apr 20, 2009 | Samsung DLP HL-P5663W 56" TV
Requesting Serivice Mode Code for Daewoo CRT Standart TV
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 21, 2017 | Televison & Video
DLP SP50L7HX
tvlamp is starting to bail out
May 24, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
296 people viewed this question
Henry  Thomas
Henry Thomas
