Question about Dryers
Fuses WHere do I find the Thermal Fuse my dryer will not start My dryer has been working GREAT until this morning. All of a sudden, when it was opened and then closed to re-start, now it does absolutely nothing. What could it possibly be?
  • pcarneygrmc Oct 09, 2008
    It's a Kenmore
  • john gagnon
    john gagnon May 11, 2010
    HI what make is your dryer
  • 943 Answers
HI thanks for your question. the most likely part to fail is the thermal fuse, located at the back of the dryer. pull the dryer away from the wall . remove back panel. clean all lint. thermal fuse is located at the left, on the air duct. a small plastic piece , with 2 blue wires to it. replace this part. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
My dryer was working fine until one morning it wouldnt even start. We have cleaned out the traps, We have checked the door... the light comes on every time its opened. The buttons seem to work and move...
This is a symptom of a blown thermal fuse located on the blower housing. This thermal fuse is in wired in series with the motor and power to the motor is cut when the fuse blows then the motor cannot run and no dryer function works. Click on the link below for the details on how to troubleshoot this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 12, 2011 | Dryers
Start light on but wont start
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
My dryer won't turn on it works great but suddenly I can't turn it on. When I push the button to start there is nothing.
The dryer functions are all impaired if the motor doesn't run. The heating circuit is activated only when the motor runs because power to the heating element is routed through the motor centrifugal switch. The problem here is likely a blown thermal fuse because power to the motor is routed to it. The motor cannot therefore run if the thermal fuse is blown.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Whirlpool WED5200T Electric Dryer
The dryer has died on me. It was working earlier this morning and suddenly it stopped. The light inside didn't come on. I tried unplugging and replugging the machine. It did not trip the fuse box outside...
Your main panel should be inside the house, and if its an old you have fuses and if its newer you have breakers. Is this the panel you checked.
Your first step it to make sure power is coming to the outlet, but you need a multimeter to check this.
If it is the thermal fuse, your vent must be clogged, because only overheating would cause this.
Go to this website, and look for the part, it should have the schematic
for your dryer and you can see where the part is.
http://www.partselect.com/
Feb 05, 2010 | Kenmore 64972 Electric Dryer
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
I have a Kenmore electric dryer series 80...It tumbles but suddenly no heat??? I need to check the fuse but I don't know how to get at it? I have the back TOP panel off & it has a piece of paper with a...
first its not the fuse or thermal fuse
if that was bad you would not get tumble
it is your heat package
remove the back panal, lower right is you heat
making sure the unit is unplugged disconnect the heat 3-4 wires and one 5/16 nut on the left lip
take out the heat and visualy inspect,,,
Oct 05, 2009 | Kenmore 84052 Dryer
It tumbles - no heat and just keeps going and going
You either have a bad element or thermal fuse. Most likely a thermal fuse. You can access it by removing the back panel. If you find that it's the thermal fuse, you will need to replace the cycling thermostat also. When it goes out, the dryer then cycles off of the thermal fuse until it goes bad.
Please rate solution
Sep 04, 2009 | Whirlpool LER5636P Electric Dryer
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
My Performa dryer stopped working.
Unplug the dryer.
Replace the thermal fuse and high limit switch located at the heater element.
The parts come as a set.
Raise the top lid of the dryer. The parts are at the back left side.
Mar 10, 2009 | Maytag Performa PAV2200
Dryers Logo
63 people viewed this question
Top Dryers Experts
