Question about Ovens
REPLACING AN OVEN DOOR
HELP!!!!!!! took door off to give oven a good clean, have done this before and managed to get it back on - but for some odd reason cannot remember how - been trying now for over 2 hours and feel like throwing it out the window. Can anybody help me quick
  • 943 Answers
HI thanks for the question. the locking clips were not locked, when you pulled out the oven door . lay stove door on the floor. take one hinge push towards the floor. lock small clip to the hinge ,do both. now re-install door. pull door towards you . unlock the locking clips. both. now close the door.thanks the appliance doc. please rate my answer thanks
Posted on Oct 08, 2008
We have an Electrolux E30EW85ESS double oven. We took the doors off to clean the class and now we can get them back on. Is there a trick to putting them back on? Thanks, Tired and Frustrated
Hello & Welcome to FixYa
This video gives you step by step instructions for replacement:
Please get back to me if you have any other questions.
Kevin
Aug 16, 2011 | Electrolux E30EW85ESS Electric Double Oven
My oven is an AEG. The oven in your video is a Smeg. I need to remove the door to clean the oven and then replace it.
Open the door to the first stop, or what is called the "vent" location. This will be about 3 inches open. Lift up on the door and pull up and out. Set the door to the side and keep the arms on the bottom in the same position, do not let them close. Clean the door, when done and set the door back in the slots the same, open the door all the way, and close it. Done. Hope this helps Fix Ya up.
Jun 15, 2011 | AEG Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Aug 07, 2006 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
434 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
