Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore range serial # 95025101 mod# RL3910680
The oven will not work and the display is flashing E1 - F2 Would you be able to tell what problem is indicated by this code?
thanks,
Jesse
  • Anonymous Oct 18, 2008
    #9578100 DRIVING ME CRAZY, I'LL HIT THE CANCEL PAD AND IT'LL COME ON FOR ACOUPLE MINUTES THEN BEEP 3 TIMES AND A FEW SECONDS LATER BEEP ONCE. WHEN THE CONTROL PANEL IS OFF THE TOP OF THE STOVE STILL WORKS, BUT TO GET THE OVEN TO WORK YOU HAVE TO TOUCH THE CANCEL BUTTON, THEN IT'LL ONLY STAY ON A FEW MINUTES BEFORE IT BEEP AND E1 F2 COMES BACK. WE JUST REPLACED THE MAIN BOARD FOR $300 BECAUSE OF THE F1. HELP HELP
  • 172 Answers
Hi Jesse,
The E-1 is letting you know that you have a problem with your oven control. This is the main control board for the oven. There is 3 things that can be done to solve the problem before you have to replace the board.
1: One of the buttons on the touchpad could be stuck. Press each button repeatedly making sure you feel them clicking out. Then disconnect power for 5 minutes. Check to see if problem returns.
2: Remove the control panel and check the ribbons from the touchpad to the control, they can sometimes work loose and need to be re-installed.
3: You can try to reset the control by disconnecting power and waiting 20 minutes then reconnect the power. Turning off the breaker will work fine for this.
If these do not solve the problem you will need a new control. If i have your complete model number I will be happy to give you a price on the part. Good luck with your repair and please dont hesitate to give us a call or email. Please also rate me. Thanks
Mike Anderson (Owner)
Anderson Appliance Center
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
What does an E1 F5 error on a Kenmore stove mean.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Nov 23, 2009 | Cell Phones
Kenmore 665-9580 error code ''E1 F2''
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
Trying to self clean my kenmore electric oven get error msg e1 f5
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
After selfcleaning my electrical range Kenmore the door still loc
Jun 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore stove and it keeps flashing F2, I have unpluged it, could you please tell me what is wrong with it
is it e1 f2 or just f2. usually f2 means you have a shorted keyboard you need a new keypad.
May 28, 2009 | Kenmore Ovens
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
141 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
