Question about Jenn-Air HV363 Kitchen Hood
Jenn-Air Downdraft ducting roof Rack w/flapper
I am looking for a high quality roof mounted termination vent cap for 8" O.D. round ducting for my Jenn-Air downdraft Stove Top/Convection oven. The reason for the 8" ducting is that I am using insulated stove piping out of the wall of the house into a cold porch then up through the roof. I have come across a Broan Vent Cap that will accommodate 3-1/2" by 10" rectangular ducting and/or 8" O.D. round ducting. The problem with this Broan unit is it has an aluminum flapper that has no counter resistance mechanism to keep from readily flapping open and shut during weather related wind events. Is there something better out there? I found you guys through a Jenn-Air link. Help!
  • Anonymous Mar 12, 2014
    Lots of cold air coming down unit that vents through the roof.
Go to www.luxurymetals.com
there are many good high quality vents on the site
Posted on May 26, 2009
    Novelist:
  • 171 Answers
Hi Snowflow,
I'm Harvey the Master Plumber.
Your problem is: You are looking for a high quality roof mounted termination vent cap for 8" O.D. round ducting for your Jenn-Air downdraft Stove Top/Convection oven. The reason for the 8" ducting is that you are using insulated stove piping out of the wall of the house into a cold porch then up through the roof. You have come across a Broan Vent Cap that will accommodate 3-1/2" by 10" rectangular ducting and/or 8" O.D. round ducting. The problem with this Broan unit is it has an aluminum flapper that has no counter resistance mechanism to keep from readily flapping open and shut during weather related wind events. Is there something better out there? You found us through a Jenn-Air link. Help!
An 8" B-vent cap should work fine. Can be purchased at any plumbing supply. Just make sure you attach it with screws.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
What is the minimum vertical vent distant from top of water heater to top of cap. Water heater is stand alone outside furnishing water for military force provider showers unit.
Generally 40 feet for ordinary atmospheric-vented household water heater...
Straight run to roof.
Atmospheric means no power vent... just hot air drafting upwards
Google search: gas vent height code
Atmospheric venting code depends on 4 basic factors:
Diameter of vent--- bigger vent, more draft
How many water heaters are connected to same vent
BTU per hour rating of water heater-- the more gas that is burned per hour, the bigger the vent needs to be
How straight the pipe is -- are there any horizontal or lateral runs
http://www.ameri-vent.com/files/assets/files/1366372183_Sizing26ApplicationGuide1.pdf
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
http://waterheatertimer.org/pdf/checking-the-draft2.pdf
Other factors can include
-wind conditions... higher wind across top of vent pipe on roof can reduce draft, and cause downdraft that blows deadly CO into same room as water heater
-vent termination near high walls, trees, high roof peak etc will reduce draft or cause downdraft
-amount of incoming air supply... if water heater is inside a closed room, then there is no air to draft up the pipe, burner will shut down or burn lazy yellow instead of clear blue
-stuff piled up around water heater that obstructs air intake
-dirty air intake screen that reduces air intake
-vent fans inside same room as water heater that pull air down the vent and cause reduction in water heater draft
-generally elbows reduce draft by 10%
-vent cannot terminate near any window door or air intake for another gas appliance
-bird build nest on top of vent pipe after vent termination falls off
-highly acidic gas by-product causes large amount of condensation inside pipe that burns hole in pipe or drips down and damages combustion parts...blower and inline condensate trap and drain might be required
-multiple water heaters installed on same vent line.
Gene
Water Heater Timers Save Money
Mar 27, 2015 | Water Water Heaters
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Installing downdraft venting
Richard, you should be ok, you may want to check it periodically to make sure that grease isn't building up in the low spot... You are adding a couple of bends, but it should still draw well.
May 10, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air downdraft
They should be pretty close to the same, if not, it would would very inexpensive and easy to modify or adapt the new one. Mostly the vent piping would have to be modified. Like I said though, you shouldnt have a problem at all.
Nov 16, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air HV363 Kitchen Hood Logo
565 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
