Question about Cameras
I just bought a finepix 8.3 camera and set it up. Everytime I take a picture the screen goes black and the camera freezes and I have to remove batteries and put back in to get camera on. I have lost my receipt so cannot take back to the shop......PLEASE HELP!!!
Buy another camera, preferably a Canon.
Posted on Oct 08, 2008
Is Fuji FinePix A700 compatible with Windows 8
It doesn't matter to the camera what type of computer you have.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Dec 07, 2013 | Fuji FinePix A700 Digital Camera
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Camera freezes after taking picture
I had this problem with my s1000 Fujifilm, but solved it by changing the standard SD card for a SDHC class 4 card. It no longer freezes when a flash is used! I've tried a 4Gb and a 16 GB SDHC class 4 card and both are fine.
Bazz
Nov 25, 2008 | Fuji FinePix S1000FD Digital Camera
Lcd screen stuck in usb mode?
Try removing batteries and card and leaving them out for a while to allow camera settings to default.
Replace batteries only and see if you get "Card Error" message.
If you get this, then try again with card fitted
Check firmware version
Possibly card storage too big. Upgrade firmware to version 1.77
If you have no user manual there is a PDF version available to download here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a330-zoom/Support
All the error messages are given in the manual with possible solutions.
Aug 25, 2008 | Fuji FinePix A330 Digital Camera
LCD Screen help
How do you get the camera back to the original settings
May 18, 2008 | Fuji FinePix V10 Digital Camera
Formatting sd card
That happened to me too, bummer.
Nov 20, 2007 | Fuji Finepix F50FD Digital Camera
Fuhifilm finepix a700
Can you play back pictures and is the quality of these ok ? If you can but there is no image in capture mode then the CCD sensor is faulty and needs replacing.
Sep 10, 2007 | Cameras
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Oct 15, 2006 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
