Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven not heating properly
I have a GE Spectra JBP66 electric oven and it will not heat up to the proper temperature. It does get hot but it never reaches the appropriate temp.
  • voodoollama Oct 17, 2008
    Same problem - oven is ELECTRIC! Broiler works but oven takes a long time to heat and never reaches temp. Stove top works fine.
  • 943 Answers
HI thanks for your question. the problem you have is with the bake igniter. a common problem with gas ovens the igniter should be replaced. thanks the appliance doc.
Posted on Oct 12, 2008
  • Leigh Potter
    Leigh Potter Mar 21, 2014
    I don't believe an electric oven has a bake igniter. A gas answer to an electric question may be confusing to the novice.
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Spectra XL 44 takes 45min to preheat to desired temperature ie: 400 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Jul 16, 2010 | GE Kitchen Ranges
GE spectra jbp66 oven is off but F2 error comes up and oven turns on and wont turn off. ive already unhooked and rehooked temp probe and took out the plastic connector and used wire nuts instead and...
Hi There
I have found this for you to read and hope this helps you.Let me know how it goes.
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge gas oven not working
thermocoupler needs to be replaced...
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
527 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
