Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
Bosch vacuum Motor turns off after a few minutes
The motor will turn on at first and work but then turns off after a few minutes. It is still getting power because the headlights stay on. Any ideas?
Thanks
  • Anonymous Nov 19, 2008
    The filter seems clean - there is airflow around the hose and the powerhead...any other suggestions?
    Problem Solver:
  • 6 Answers
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Posted on Oct 08, 2008
My vacuum has the same problem when the filter needs to be cleaned. Just twist the filter cover to take it off, then press the red button on top of the canister to release the filter and pull it out. Fine particles of dust collect on the filter causing the motor to overheat and shut off. Take an old toothbrush and clean the filter. Install it once you're done, and the vacuum should work fine.
Posted on Jul 28, 2009
Have you cleaned the filter? That was the problem when I experienced the same issue
Posted on Oct 15, 2011
The beater bar works but the vacuum canister shuts off after a few minutes. Then the switch will only turn the beater bar on and off.
You may have a thermal reset in the vacuum motor that shuts the motor off if it gets hot. Clean the vacuum and replace the filters.
Feb 28, 2016 | Vacuums
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
My vacuums power shut off while vacuuming
Its a good chance that your vacuum motor has either shorted out or become burnt out, this can happen after a few years of use. My only real suggestion, being what i would do in your situation, either contact dyson and try and get another motor, alternatively, contact a 2nd hand motor place, maybe a white goods store, and they may have a vacuum motor to suit as Dyson spare parts can be expensive. I hope this offers some assistance.
Nov 26, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vacuum won't work-
sounds like the motor might have bit the dust.try this,unplug the vacuum and reach under where the brush rolle is and try to turn the roller by hand a few times,if you can't turnit then then the roller is jammed.take the belt off and then turn it on and see if it runs then.let the motor cool down first the motorguard might be keeping it from running.just let it cool down for about 20 minutes then try it
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Vacuum will not power on...
your repairman missed the thermal fuse in the motor compartment
Aug 10, 2008 | Bosch BSA2200UC Bagged Canister Vacuum
Motor or pump problem?
my guess is you burned out the motor. go to thehooverstore site. look for your machine. they have a parts list for just about any hoover made.
Sep 07, 2007 | Hoover F6020-900 SteamVac Upright Vacuum
Vacuum won't turn on
there is an overheat stat which turns motor off. possible cause is filters blocked or a blockage elsewhere - no air flow and the motor overheats
Mar 26, 2007 | Bosch Cyclone Jet Upright Vacuum
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
759 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
