Question about Epson Stylus DX6050 All-In-One InkJet Printer
Epson DX 6050 Paper feeding issues
My EpsonDX6050 was working fine until yesterday when the paper stopped feeding correctley. The printer feeds the paper from one side but not the other. Any solutions?
    Guru:
  • 859 Answers
I'm here to FIX your problem. I don't want to be helpful. I want to FIX your problem. If you will work with me, I will work with you until this is FIXED.
The paper not loading from one side is a problem with the pickup and feed roller on one side. This happens when rollers dry out and actually shrink as a result.
To resolve this, all we need to do is 'rehydrate' the rollers. There are solutions you can buy to do this and maybe it will come to that with yours. But, I've used this method below for years of working on Ink Jets since they first came out in 92.
Remove all paper.
Get a clean sponge and dampen it fairly well.
Now, you will want to repeatedly press the Paper Feed button while holding the damp sponge firmly against the pickup and feed rollers you can see while looking down your paper tray of your printer. You should be able to see these rollers quite easily.
The trick is to keep damping the sponge and pressing it against the rollers while pressing Paper Feed a lot of times. How many times? Well, this varies. But you will want to do this at least a dozen times on each side of the pickup rollers to start with.
Once, you are done with this initial attempt, you will want to give the rollers a chance for their surface to dry to the touch. Then, insert a full load of paper and press Paper Feed and see if your printer loads the paper correctly. If it attempts to load and does so better than before but does not quite finish, pull the paper out, its okay to do this, and rehydrate the rollers some more until the paper feed works as expected.
Let me know how this works out for you. I can direct you to a vendor on the internet to buy some roller rejuvenator later if its actually needed. I have found that you can do this trick with the damp sponge on an as needed basis from time to time and achieve the same result.
If, however this does not make any difference in your printers ability to pick up and feed paper then you have a mechanical problem and if under warranty you'll want Epson to fix it. If not under warranty you could have Epson fix it but you'd probably be better off getting a replacement. You will have to decided on that once Epson quotes a price to repair and replace the damaged parts.
Please use the comment text area below to communicate with me and ask any questions to explain something or ask a further question. I will receive an email alert and will get back with you as soon as I am able. This will depend on our time zone differences.
Regards,
Worldvet
Posted on Nov 09, 2008
  • JensHansen Sep 01, 2011
    I did what you suggested, but it didn't help, unfortunately.
    Then I took a piece of hard glossy photo paper and had that rolling in to a point of obstruction. I pulled the paper in the non blocked left side in order to get what ever might have been blocking loose, and to get the paper through. The paper ripped, and I had to clear it out of the back.
    At the next test print some kind of a miracle happened. The plain paper went straight through and with it a solid brass coin, that has caused the jamming in the first place. The printer works now, and I am 20 DKR richer.
    Crazy.
Epson tm u220b manual feed works, autofeed does not work
Probably the rubber sheet pick up "fingers" have hardened over time and are unable to grip it. This is a common autofeed problem.
Nov 03, 2016 | Epson Office Equipment & Supplies
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Epson c66 not feeding paper
Main reasons for a paper feed problem like the one you describe are:
-. One of the sensor actuators (normally It will be a little plastic lever on the path of the paper) is either broken or blocked. It could happend if you attempt to remove a paper in the opposite direction of the normal paper movement path. Check if you can see something like that near the point where the paper stops.
-. The second option will be dirt on the feed rollers. If you can remove them easily the you can try to clean them using water and soap. In that case what is happening is that the paper reaches the first sensor but the printer doesn't knows the paper is stuck until It detects that the paper arrives later than expected to the last sensor (a timing issue). As the printer keeps printing this is the most probable cause to your problem.
I don't know that model of printer in particular but I hope this serves you as a guide to pinpoint the issue.
Jul 07, 2012 | Epson Stylus C66 InkJet Photo Printer
I checked the steps on your Epson R340 Paper Feed problem. Both of our R340s are about a year and a half old and they are both having the same problem. There is nothing wrong with the paper . . . it...
hello, eventually the feed roller will need to be cleaned, it collects paper dust and dust and inks, so becomes smooth, and unable to grab paper properly, cleaning with alcohol, yes it does clean but dries rubber, WD-40, is waht i use, but i allow it to be absorbed into roller, then wipe off the excess, then try feeding paper.
Oct 14, 2010 | Epson Stylus Photo R340 InkJet Printer
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Oct 20, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus photo 1400 paper feed
I have the same problems. Very frustrated. Has anyone found a solution to this??
Mar 03, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus DX6050 All-In-One InkJet Printer Logo
492 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
