Question about Panasonic CYVHD9401 9 in. Car Monitor
How do I connect it to my car's speaker system?
I bought a vehicle with the Panasonic DVD player in it, but it didn't have the wireless speakers or remote control, nor did it have the operating instructions. I cannot seem to obtain the Operating Instructions from Panasonic (instead of operating instructions, they provide worthless installation instructions). I can't get the DVD system to work (I believe I probably need to buy a remote control, but without the operations manual which list the replacement parts, I don't know what to buy. I also want to connect it to my car's speakers but am not sure how to do that? Please advise.
    Scholar:
  • 92 Answers
If you don't have a remote control for it, that's probably a good part of the problem with the operation of the unit.
Getting the sound to come out over your car stereo speakers depends on the type of audio system you have. If it's a factory system or an aftermarket that does not have an aux. audio input you could get an FM modulator to plug in to the output of the player and broadcast it via FM to your radio. If you have an Aux. input you can get an adapter cable to plug it in with.
As for the operating instructions, sometimes it's helpful to try the manufacturers website from other countries, ie: Canada, Australia etc. panasonic.ca or panasonic.au or panasonic.co.uk
You could also find a local dealer who sells similar products and see if you can either order one or at least get a part number to find one yourself.
Posted on Oct 08, 2008
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
I got a panasonic sc-bt100 from sears used but i cant connect the rear speakers i think im missing a part do you need to put something on the dvd player so the rear speakers could work?
There should be a "module" that you slip into a slot on the back of the main SC-BT100 unit...this is the transmitter that sends the signal to the rear speaker unit. The rear speakers, while "wireless" to the main unit, are wired to the separate unit that should have come with your set-up.
Oct 02, 2009 | Panasonic SC-BT100 Theater System
Center and wireless speakers not working
are you tryng to get digital surround ? you can only get left and right audio or virtual surround sound if there is no optical or coax digital audio input connected from the sources digital output for that selection
Mar 06, 2009 | Panasonic 1000W 5.1-Channel Home Theater...
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
Aug 01, 2008 | Nesa Vision Car Audio & Video
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic CYVHD9401 9 in. Car Monitor Logo
254 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
