Question about Siemens Electrical Supplies
Electric panel broken breaker tabs
    Sergeant:
  • 352 Answers
Replace the breaker, I'm assuming you mean the breaker itself and not the slot in the cover.
anaanymous
Posted on Oct 11, 2008
I just bought a 1997 Fleetwood prowler and only have electric to the front half of the recipt plugs nothing in the galley or above the table what can cause this
Several things.
I hope you will be able to locate the fault.
Start with a bad circuit breaker.
Once in a while, a circuit breaker will be good-looking, but be no good.
Test that with a electric meter at the side where the wire attaches under a screw.
If all circuits are HOT at the circuit breaker box, suspect a burnt or broken wire somewhere between the box and the "dead" area.
Know that traditionally, the outlets and lights are not in parallel, they are often in series.
That means, an outlet can have a broken or fried connector tab between one plug and another, which can can use the whole system to be dead.
Look at a duplex outlet that is "loose". ( Hold it in your hand)
See the 2 tabs on the sides that connect the top and bottom outlets. If a tab is missing, one plug will be hot, the other dead. If wires go from the dead bottom one to other outlets or lights, they will all be dead also.
God bless your efforts.
Nov 10, 2015 | Cars & Trucks
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Apr 12, 2013 | Televison & Video
How do you get the circuit breakers ot of the box its a square D type HOMT please help we have no electricity in camper
Very simple: Unhook the wire from the breaker and then pry up at the center of the box... the breaker slips over a blade at the center of the box and tucks under a pair of tabs near where the wire connects.
That is, the breakers tip up from near the center of the box toward the outside.
You can use aa flat screwdriver to go right between the breakers at the center to nudge them up to start... DO NOT put the driver in more than 1/4 inch.
Sep 14, 2010 | Square D Qo 100 Amp Breaker Box Qo120m100...
I hace a 2003 Kenmore Electric Ran ge #790-95682. Five minutes after turning the oven on to preheat, I heard a loud poppong noise and spark near the left side of the burner controls on the display panel....
your bake element blew look at it to see if it is broken. if it is replace. the main breaker blew in breaker box .most likely .or a wire is burnt take off back panel and look .unplug first .good luck
Aug 23, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
How to setup a thqp250 in a box?
These breakers are 1/2 size and only fit in an area of a panel designed for these. The bus bars must have extra tabs for these breakers. Before 2008 you could only have 42 breakers in a panel, so only some of the slots were reserved for these. Secondly, since this is a two pole 220breaker it must be in two spaces. This leaves a 1/2 space above and below the breaker. You could add a single pole breaker above and below. Now compare these in size, is there any way they can be as good as a full size breaker?
Aug 04, 2010 | Connecticut Electric THQP250 General...
My roper electric dryer heats when running for 5 mins. then trips circuit breaker
May not be your dryer. Many times a loose wire at the circuit breaker panel will cause the breaker to get hot and then thermal trip the breaker. It may be worth a look. Remove circuit breaker panel. Turn dryer breaker off. Check wire lug screws for being loose. Make sure screws or snug but do not tighten and strip the threads. Be especially careful if the wire/cable is silvery aluminum colored. If that is the case make sure there are not any broken strands at the breaker lugs. If possible use a clamp on amp meter to check the operating current. The current should not exceed 80 percent of your breaker rating. It is most likely a 30 Amp 2 pole. You may also have a bad breaker. If a breaker has a weak spring or bad contacts it will easily get hot under load and trip. My best guess other than a dryer motor locking up or dragging. New breakers are inexpensive at HD or Lowes etc. Be sure to get the exact brand and model if replacing.
Feb 27, 2010 | Roper REX3614KW Electric Dryer
Oven repeatedly shuts off and "PF" appears on digital screen- Kenmore gas range. We have never used the self- cleaning option for the oven.
The code being displayed denotes "PF" for Power Failure. It could be that you have a loose connection at either the range connection in back or at the outlet where the range is plugged in. You could even have a loose wire on the breaker in your electric panel.
First, shut off the breaker to your range and then you can pull it out from the cabinet and remove the access panel on the rear of the range. Check the nuts that hold the cord terminals onto the power tabs in the range. They should be tight and clean, without corrosion or any broken strands.
Now, with the power still off at the breaker panel, check the range outlet at the floor or wall. Remove the cover screw and look at the connections to make sure they are tight and secure as well.
Sometimes Aluminum service wires are used and the connections can become "glazed" which can cause a high resistance connection. The wire should have been abraded with a wire brush and an oxide inhibitor added to prevent aluminum oxides from forming on the wire strands and the electric terminals. If yours is Aluminum, you might wish to add an oxide inhibitor to these connection points to make a better electrical connection.
After that, reinstall the cover and plug the range back in, put the range back into place and go to the electric breaker panel and carefully check the wires going to the breaker to make sure they are secure and tight. You'll need to remove the panel cover to get at the breaker screw connections, so care is needed when doing this.
Once you've done these steps, you can put everything back together and turn the power back on and see if it resolves your issue.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
Dryer started up as normal, but, midway through cycle, it stopped running. Timer was still going, but dryer is not spinning.
Can you hear the motor turning? If yes, it probably has a broken belt that drives the drum. If no, check the house electrical power panel to reset the dryer breaker(maybe, only one of the breaker pair tripped). If breaker trips again, you have an electrical short in the dryer cabinet somewhere, usually in the heating element in back of the drum. Good luck!
Jul 09, 2009 | Dryers
Electric clothes dryer will not turn on
Check in the upper corner of the dryer when you open it. There should be a slot where a little tab sticks out. This is the door switch. The tab should stick out about 3/4 of an inch. Is it broken? Dave www.washermd.com
Dec 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Circuit Installation
The process contain a certain degree of risk, but if you follow all safety steps, you should be just fine. Most standard electric panels have a main disconnect switch or breaker at the top of the panel or load center. It is a code requirement. If the load center doesn't have one, then look for the main disconnect at a different location possibly near the electric meter. Turn it off. You better have a flashlight handy or a caving or miner's helmet, because you are going to need a light source. Circuit breakers plug into the load center. The electricity flows into each breaker via a large metal strip inside the panel or load center. It is called a bus bar. This strip is HIGHLY dangerous. Touch this strip while it is energized and you will very likely die. If a screwdriver you are holding slips and touches it, expect nearly the same result. Keep in mind that even though the main breaker may be off, the bus bar may be energized for any number of reasons! Also, the wires leading into the top of the main disconnect are always energized and represent a life safety hazard. In other words, the inside of an electric panel or load center is ALWAYS a dangerous place to be. The black wire to a circuit attaches to one end of a standard or AFCI breaker. The location is almost always a hole that is drilled through a threaded cylinder. A screw twists into this cylinder and tightly clamps down the wire. When installing a new breaker, I always find it easier to attach the circuit wire to the breaker before I plug the breaker into the panel. When removing a breaker, I usually unplug the breaker from the bus bar and then remove the circuit wire from the end of the breaker. Make sure the breaker is in the off position. The end of the breaker where the circuit wire attaches almost always has a small notch in it. This notch fits under or slides into a metal tab strip that runs parallel with the bus bar. This is what stabilizes the breaker. Without this secondary attachment, the breakers would flap in the panel much like a sail that is not tied down to the mast or the side of a boat. Tip the end of the breaker so the notch slides into the metal tab. You then align the breaker with the bus bar and push it down onto the bar. The tension tabs on the breaker open slightly and grip the bus bar as the breaker seats itself. If you feel the breaker seated itself correctly, simply turn it on. All should be well. Remember to follow the instructions that come with the breaker. Always follow the sequence the manufacturer suggests. AFCI breakers require one additional step. You need to locate the white wire that is paired with the black wire in that circuit. The white wire actually attaches to the breaker as well. There is a coiled white wire that leads out of the breaker. This white wire attaches to the neutral bus bar in spot that is vacated when you disconnect the white wire of the circuit. If this answer scared you, call an electrician!
Aug 27, 2008 | General Electric 20 Amp, 1 Pole Thick Type...
Electrical Supplies Logo
229 people viewed this question
Top Siemens Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Steve
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
