Question about Cameras
The lens of my digital camera has a problem zooming in and out correctly and some times loses focus.Also the camera turns off with the lens in a zoomed out position. how can i fix this problem.
  • holzedi Jan 29, 2009
    when I zoom in or out the camera turns off?
  • 489 Answers
Hi
It sounds like your lens is defective and needs to be cleaned, repaired or replaced if you are seeing an error message that reads "E:18", "E:61" or "Lens error, restart camera" or something similar. Turning the camera off and back on again will not fix the problem unfortunately.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Posted on Oct 08, 2008
Panasonic H-FS014042 not working with GF1
If you placed the lens correct, till it clicked while turning, it should work correct. Did you check if there was anything on the contacts, before placing the lens?
Can you focus manually? and is your camera in the auto focus mode?
I can't make more at this moment. Success.
Jan 02, 2014 | Panasonic Camera Lenses, Flashes and...
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Does the fuji fine pix camera have a focus button? where is it?I want to be able to zoom in on a subject without losing focus.
No, your camera does not have a manual focus button.
Even if it did, you wouldn't be able to keep focus while zooming.
Only very expensive lenses maintain focus regardless of focal lenght.
The correct procedure is to zoom and then focus.
Nov 12, 2009 | Fuji FinePix S700 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
No picture and lens does not retract
Well some cameras has features that does not use the LCD screen of the camera, because to save battery power or to get better shots with the focus ring.
You can just use the area where you focus your eye to aim and shoot the object of image.
Try to enabled the LCD screen feature.
The Zoom Lens Wiggles 3 times because it is programmed to zoom at the standard zoom size, this is totaly normal for camera in digital and analog types.
Mar 05, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Focussing
Two possible solutions. The camera may be set to Macro. The lens may have failed. If the camera is not set to macro then the lens has to be replaced and the camera reprogrammed.
Sep 11, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
