Question about Dishwashers
Whirlpool dishwasher du1148xtpqs
My dishwasher is about three years old water will come into the machine and will drain out when i push cancel when it goes into the wash cycle all it does is hum. i have had the motor out of the machine and everything seems to be moving freely.i can put the machine into check mode by pushing heated dry and high temp wash and it has the same problem when i first found the problem the wash light was flashing. the dishwasher had been making a loud noise for a while i am sure i could replace whatever part is faulty if i knew what one it was
    President:
  • 1,462 Answers
If you are getging no pump rotation, try changing the motor capacitor - cheap part
Posted on Oct 09, 2008
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
Aug 22, 2015 | Whirlpool Dishwashers
My kenmore diswasher model 665 15772 - lock button is flashing - dishwasher will not start. Can you help me?
6/3 I bought a Kenmore Ultra Wash dishwasher, Model 665. As many others have posted, my dishwasher also do does not automatically drain, leaving about 3" of water in the bottom of the machine. The only way to pump the water from the machine is to use the Drain/Cancel button, which cancels the cycle, and the dry option, leaving the dishes wet and spotty.
I just contacted a tech rep with Sears Repair and was told this is a Factory Defect with this model. Whirlpool (manufacturer) is aware of the problem and working on a resolution. Meanwhile, Whirlpool (via Sears and K-Mart) offers a free service call to install the "retrofit kit" that should solve the problem.
Even though Sears is aware of this problem, you will be expected to jump through their hoops - did you install a disposal at the same time and knock out the plug (FYI - if the plug is not knocked out, the Drain/Cancel option will not work and the machine will not drain at all). They will also ask if there is anything blocking the drain (FYI - if there is a foreign material block of any kind, the Drain/Cancel option will not work and the machine will not drain.
If this dishwasher (Model 665) does not drain automatically, THIS IS A FACTORY DEFECT. A retrofit kit is available to correct. In the DC Metro area, the wait time for an in home service call is three weeks.
If you have this problem, call Sears 1-800-4MY HOME and schedule a FREE retrofit kit installation
ALSO, call your sales person, and the appliance dept manager, at the store where you purchased the appliance to let them know this product is defective.
Jun 26, 2010 | Kenmore Dishwashers
Whirlpool model du1100xtpq6 machine will not start clean lite flashes 7 times stops and repeats must be code 7 blinks only drain pump runs when drain/cancel button pushed
Hi, this is an indication that the water did not heat properly. Follow this link to some instructions I put together to help solve this and reset the control so you can use the machine again.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 08, 2010 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Wont run a cycle
Watervalve open?
If yes?
Has this unit an integrated waterstop with the hose interlocked with a flow detection device? Mine failed on that. Bought a new machine after 10 year of service the flow device was 300 dollars.
Apr 04, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
