Samsung DLP TV is making a buzzing sound. Sounds like something spinning. Can hear it speed up to full spend when turned on and slow down and stop when powering off the TV. Loud at times.
    Scholar:
  • 62 Answers
More than likely this is the cooling fan. I have a Samsung DLP myself, and at times, I can hear the fan running also. There could be something wrong with the fan, but I kind of doubt it. Just make sure that the TV is in a spot with lots of ventilation....otherwise, you might have to live with this noise.
Hope this helps!!
Chad
Posted on Oct 08, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
My tv makes a buzzing or grinding sound when i first turn it on and stops after the lamp warms up. is this just my lamp starting to die?
You may have a bad color wheel if your TV is DLP based. If its a Samsung then you most likely have a failing color wheel. Lamps will not cause grinding or buzzing sounds.
Jun 02, 2015 | Televison & Video
We have a Samsung 61 inch DLP tv. That started buzzing a few weeks ago when it was turned on. At first it only lasted a few seconds. Kinda sounds like a bad barring, Then this last week it began to last...
Highly likely that the sound was coming from the bearing in the color wheel assembly. When the bearing fails, the color wheel cannot spin at the correct speed, and because the speed is measured by the control board, the TV will shut down.
If you can handle a screwdriver - entire color wheel assembly can be replaced for about $100 and 30 minutes of your time.
Oct 08, 2013 | Samsung HL-R6167W TV
SAMSUNG DLP HL-R4667
It sounds like a bad color wheel (see photo) which will give a fan like or high pitched sound.
Very common on these sets and can be a do it yourself repair.
You Tube has complete video instructions for replacement for most of these models.
The wheel turns at over 12,000 rpm (very small part) and the bearings in the motor fail causing a fan like or whine noise.
If it fails all the way and shatters (it can) set will not even make it on---set is monitoring the wheel and if not at right speed or stops almost instant shutdown will happen.
see the photo and let me know if questions--replaced a lot of them and your description is classic.
Mar 19, 2012 | Samsung DLP HL-P5663W 56" TV
The compressor light is on because the unit is cooling. It it not blowing cool "ac" air. How long is this process going to take? Do I keep the ac on or do I shut it off? It is also making a...
It sounds like the compressor isnt starting just because the lights on doesnt mean it is actually on.
If it is the compressor thats making the buzz heres what to look for when you start to hear the buzz does the fan slow down and then speed up after the buzzing stops? If it does your compressor is locked up you can try to replace the capacitor on the unit. If that dont work I wouldnt spend the money to replace the compressor too much money.
Jul 14, 2011 | Amcor AL10000E Air Conditioner
When you turn on the TV it makes this buzzing sound like something is spinning inside the TV. After a while the TV cut off on its own. It has a new bulb in it.
check the fan that cools the bulb. if its rubbing something that would make the buzzing sound, and if its not cooling the bulb it will shut off when it over heats.
Sep 14, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
