Question about Lucent PARTNER18 Corded Phone
Cannot Transfer Voicemail
The Transfer Voicemail Button Does not work how do you re program the button so I can transfer voicemails. Thanks!
From the phone.
Feature 00
press the button
press Feature 14
feature 00
Posted on Oct 12, 2008
How do I program buttons on Samsung iDCS 18D? Transfer to Voicemail, DND, etc. . .
Hi I have posted a video off http://www.abbeytelecom.com showing how to do the soft key programming, a tip is when programming the transfer to voicemail - it shows as VT *** ( voicemail group number).
Aug 03, 2011 | Samsung Phone PDCSLCD12B
I need to know how to transfer a call into someone's voicemail on the Avaya 8410D.
hit the transfer button ,dial the extension of the other user and hit transfer again . or hit transfer and dial the voicemail extension and dial the voicemail extension of the other party and hit transfer
Apr 18, 2011 | Avaya Definity 8410D Phone
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
How do I transfer a call to voicemail on a Panasonic KX-T7433?
A lot depends on what you dial to get to the voice mail and if it's a Panasonic product. Normall, x165 is the VM. So, you take a spare button, label it VTR (voicemail Transfer) and then press PROGRAM 99, the button and dial 8 165 STORE. Pick up the handset and drop it back down to exit programming mode. The button can be any button, including a PF button (not many features can use it).
Carl
Sep 17, 2010 | Panasonic KX-T7433B Corded Phone
I switched my phone to another outlet in another room. I changed all the extensions to match the phone and the voicemail will not work. How do it program the voicemail button on my phone?
What happens when you dial 500? If that happens to be your VM access code, then try PROGRAM button and dial the following 90+500 STORE for 2-way record 91+500 (#ext optional) STORE for 2-way transfer to a mailbox, and 94+500 STORE for VM Transfer.
At the minimum you need VMT. I give the customer all 3 buttons.
Carl
Aug 30, 2010 | Panasonic KX-T7633 Corded Phone
Our voicemail transfer button will not work for oneparticular phone.
More than likely although the button is marked as a transfer its not programmed as a transfer button. To see how its programmed press feature *0 (button inquiry) and press the button marked transfer. To re-program the button press feature *3, press the button marked transfer,and press feature 70. that willchange the program on that button.
Oct 13, 2009 | NorStar Meridian M7310 Phone
Program a button for Direct Voice Mail
press speaker 00
press the button you want to program
press *56
Press the speaker button.
Label your button
Nov 14, 2008 | Avaya 4412D Corded Phone
Uniden PowerMax 5.8 Transfer to Voicemail
Yes, just push the record button. It's the middle button on the top just under your display. That will start recording your call.
Sep 12, 2008 | Uniden TRU8885 Digital Answering Machine
Transfer call directly to voicemail
Since you did not mension the phone system type I am assuming it is a Digital like the KX-TD500. You can transfer direct to voicemail if you have a VT ( Voicemail Transfer ) button on your phone. When you want to transfer the party you are talking to, press VT and dial the extension/mailbox number you wish to transfer the call to and hang up to complete the transfer. If you do not have a VT key you can program one of your flexable buttons as a VT key by pressing your PROGRAM button, dial 9 9, press the button to be programmed, dial 8 and the voicemail extension number, press AUTO DIAL/STORE and then press PROGRAM to exit station programming. Good Luck. ....Mike
Aug 04, 2008 | Panasonic KX-T7453 Corded Phone
DKT's wont ring from transfer
put an "H" after the extension in the voicemail, i.e. 200H, you have to put in your #656 #657 codes into the phones to integrate the voicemail. #656 91, ext of voicemail pilot, hold #657 92, ext of voicemail pilot, speed dial button (program one on the phone if it doesnt already have it), enter the number of seconds before the phone should forward to voicemail, i generally do 16, hold. that should fix that!
May 22, 2008 | Toshiba DKT-2010 Corded Phone
Lucent PARTNER18 Corded Phone Logo
435 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
