Question about Ovens
Creda 48331 trigger board
Please advise if this component controls the oven timer
    President:
  • 1,462 Answers
No it doesn't
Posted on Oct 09, 2008
Model no 360e ,how doI set oven timer
Hi John, The link below is a user manual for a creda oven, It says you have to set the time and date before the oven will work, Pages 11 through to 14 will show you how to set the time and date.... CHEERS..
http://www.manualslib.com/manual/723002/Creda-Continental.html?page=1
Mar 30, 2016 | Creda Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Elements in oven not working
Hi
Check for the wiring between the element and the control board. Also remove the element and check for the resistance of the element using a multimeter(it should be around 1.3-1.5 Kohms).
After this is checked, please check the connections of the timer selector switch and also check for the any burnt components on the control board.
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Frigidaire Ovens
Creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Creda Ovens
Ovens Logo
144 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
