Question about Whirlpool Refrigerators
Whirl pool refrigerator ice maker won't make ice
The refrigerator is a side by side. the water and ice come out the door.
the water flows freely however, the icemaker has stopped making ice.
the electronic eye light is still lighting up and every once and awhile
a few ice cubes fall into the bin?
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
SOURCE: Whirl pool gold GD5RHA side by side.
We had the same problem and I AM NOT a repairman. I found that with a lot of freezer door opening, the rubber fill tube, which fills the ice maker tray, had frozen up inside the tube. I had already replaced the ice maker, and still no ice. I am sure a repair person will shudder, but I simple put a Phillips screwdriver up the tube and found the ice was not allowing the tube to refill the tray. CAREFULLY, use the tip of the screwdriver to dislodge the ice and clear the tube. These units do not cool or freeze quickly, therefore keep the doors closed as much as possible and don't let kids stand with the door open while they gaze into the depths while making their decision.
Posted on Dec 28, 2007
  • 363 Answers
SOURCE: icemaker makes too few cubes
Find the water source for the ice maker(most are under the kitchen sink and are tapped off of the cold water line to the faucets) You need to either shut off the tap by turning it clockwise until it is closed. Then you need to disconnect the vinyl tubing from the valve. get a bucket and place it where it will catch the water from the tap. Gradually open the tap by turning it counterclockwise until water starts to come out of the valve. If you have a large enough bucket open the valve all of the way. If the stream of water does not change then the valve is bad and needs replacing. If the stream is nice and strong then the valve is ok. Turn the valve clockwise to close it, reattach the vinyl tubing and open the vale all of the way. This should improve the quanity of ice cubes. If not then there is a cripmp in the vinyl line between the tap and the solinoid valve on the back of the refrigerator.
Posted on Jul 18, 2009
  • 36 Answers
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Posted on Jul 24, 2009
  • 106 Answers
SOURCE: Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Posted on Oct 30, 2009
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Water will not flow into ice maker
This could be 2 reasons for this The water control valve on back for the ice maker is defective or the thermostat inside the ice maker is defective. You can pore water into an empty ice maker and let it freeze. If it cycles and does not refill with water I would say that the water control valve is defective. Your refrigerator has 2 dual water control valves one is for the water filter assembly the one on the back is part number 61005626
Let me know what you find, Thanks sea Breeze click link below and enter model or part number in search feature.
http://servicepartstec.blogspot.com/
May 27, 2009 | Maytag MSD2756GES Side by Side...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Dec 24, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
