SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
SOURCE: PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
SOURCE: Optoma hd65 wont power on
The problem sounds like the lamp ballast is bad--it's a circuit that initially starts the lamp and then keeps it burning--the lamps are like a welder's arc inside of a glass globe. When you push the power button, the ballast uses a spark of electricity (sort of like a spark plug) to get the initial arc going and then switches to low voltage, but HIGH amps to keep it going.---Rick
SOURCE: optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
