I have purchased a new DVD Player. Please help me connect to a TV with cable.
  • 417 Answers
You need a Scart cable to connect the two. The instruction manual should tell you which port to connect to on the DVD (usually TV). The port on the TV should say AV in or similar . Sometimes you have to tune a TV channel to view the DVD but usually if you select AV on the TV it will play automatically.
Posted on Oct 08, 2008
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
Hi, i need to connect my tv with the dvd player...can't find the codes for either...please help
hi,
if ur tv and dvd player has hdmi connectivity, then purchase a hdmi cable and install it. if not it both will have component video connection. for that u need component video cable and one stereo rca cord for connecting video an audio respectively. bought it and install it.
ok
Dec 15, 2010 | Televison & Video
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 14, 2009 | Televison & Video
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
How do i connect my dvd player?
It depends on what outputs your DVD player has and what inputs your TV has.
If your DVD player has HDMI outputs and your TV has a HDMI input then you will need to purchase a HDMI cable and connect the 2.
If either your DVD or TV does not have HDMI then you will need to move on to either a component video cable which has 3 cables on the end which are colored red, blue and green. You will also need to connect for audio which is a cable with 2 colors, red and white.
There are also s-video and the regular old way of connecting which is a 3 cable design which has a yellow end for video and a white and red end for audio.
If you need any more help or can offer more info on what connections your TV and DVD player have then I would be happy to help.
Jan 12, 2009 | Samsung LN26A330J LCD TV
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
