Question about HP LaserJet 3380 All-In-One Printer
HP 3380 Laserjet All in one - paper wrinkling when printing left side
Hi - I have a 3380 All in One - the paper is wrinkling on the left side every time I print/copy. I noticed a ticking kind of noise starting a few days ago, before the wrinkling started. I opened the back and there are little pieces of silver/gold paper rolling up on the opposite side from wrinkling. I changed out toner - did not make a difference Any suggestions?
  • deb w May 02, 2009
    I am having the identical problem with the paper wrinkling on the left side every time I print/copy. I
    silver/gold paper rolling up on the opposite side from wrinkling. I also tried changing the toner and it hasn't helped. Is it something I can readily fix and/or will it be expensive to repair.
Replace the fuser
Posted on Oct 09, 2008
Paper wrinkles on one side when comes out of printer
hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
Jan 31, 2010 | HP LaserJet 1300 Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Printer mispick and how to solve it? I tried to open the door to take paper out, but left a little piece there I believe since the paper was broken. Now, I can not print anything and can not find any piece...
Clearing a paper jam - (or leftover bits of paper)
The LJ 3380 may be shown in this tutorial from HP: (do not try any disassembly other than opening the product doors as suggested in this tutorial)
HP LaserJet 3330 Clear Paper Jams
If this info is helpful, please vote.
Dec 29, 2009 | HP LaserJet 3330 All-In-One Printer
The paper wrinkles up while going through
This is possibly down to the upper fuser roller wearing and catching the paper when it goes through the fuser. The upper roller surface breaks up and splits
Oct 04, 2009 | HP LaserJet 1300 Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Paper jams and wrinkles every time
If you slide open the area in the back of the printer where you remove the paper jam, you can see two plastic tabs (one on the left and one on the right). They should both be free for the paper to pass. Look around to see if there's any other obstruction.
See if the paper will print without the wrinkle with the back piece open. If it does, there's an obstruction in the paper path such as a paper clip or money. Has happened.
If there is no wrinkle coming from the back when it's open, there there problem is the paper moving through that last piece. Look for an obstruction (First Paragraph of this).
Dec 04, 2008 | HP LaserJet 1200 Printer
Bad fuser Laserjet 3380
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
HP Laserjet 3380
If it is from the adf which is on the top then there is a small piece of paper stuck in the back. open the lid and you will find a plastic holder in the back. This helps the paper turn through the adf. Usally the paper is in there or this is out of positions which will cause this.
May 12, 2008 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3380 All-In-One Printer Logo
867 people viewed this question
Seeker5211
Seeker5211
