Question about Comdial Impact 8024S-PT Corded Phone
Can call forward outside system be programmed from the user handset on a comdial fx ii impact system?
Need to see if there is any system programming needed to have calls bound for an extension to be forwarded to an outside number
  • Anonymous Mar 25, 2014
    call forwarding to outside line
I do use CFOS, but to get it working, I did have to do some system programming. You have to turn on the master CFOS enable system parameter, and you have to assign a button for the station to be a CFOS feature button in the Station programming screen. The outside number to which calls will be forwarded is also assigned on the same screen... I've never found a way to set the number from the station itself.
Posted on Oct 08, 2008
  • booktag
    booktag Mar 14, 2013
    How do you turn on the master CFOS enable system parameter, please?
Change the line selected when lifting the handset (from #4 to #2)
that is not a user option it must be programed by a tech. it is a feature called idel line prefrence the other way iy can be accomplished is by using a hunt group but you will still need it to programed by a tech, you can contact me by email @ brcrory@buyrite.com
May 05, 2010 | Comdial Impact 8124S Corded Phone
Can't activiate the headset feature.
it has to be setup from programing you need a tech
Mar 17, 2010 | Comdial 8024-S Impact 24-Line Phone
Programming Ext #'s
hit the options key till you get to query then hit the intercom key or just intercom the operator and see what extension it comes up with
Jan 27, 2010 | Comdial Impact 8012S Corded Phone
Programing
Try Googling (comdial)(8124S)(manual) without parens to get instructions.
Sep 30, 2017 | Comdial Impact 8124S Corded Phone
I have a Comdial (Impact) DSU II Expandable Systems, LCD Speakerphone Station. The LCD screen and lights for lines, etc. are not working. I can make and recieve calls, although do not know what line I am...
it could the prot is programed for the wrong phone type or the [port could be bad you can contact me at brcrory@buyrite.com depending on what area you are in i can help you or recommend a dealer in that area
Nov 30, 2009 | Comdial Impact 8312S Corded Phone
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
Change number of rings on Comdial Impact
Thsi change needs to be made in sys programming. Usually with a pc and vmmi software.
If you have that, call up your station and there is a setting for station fwd to vm setting you can adjust.
Dan
Mar 12, 2009 | Comdial Avaya Partner ACS Phone
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
Aug 29, 2007 | Comdial Impact 8024S-PT Corded Phone
Lands Phones Logo
592 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
