Faulty TV ( CRT type)Television blue hayse over the picture on digital
Freeview digital picture has a blue hayse over the picture. When switched to anologue the picture is working OK. Has anyone any idea what component may cause this fault
  • 79 Answers
Hi there
the blue haze is probably down to the scart lead ( it splits the r.g.b. signal) try getting a scart lead that is 'wired to all pins', you can tell by looking at the scart plug, if it is full of pins it is normaly o.k
if it is missing some pins i.e. there are spaces which look like there should have pins there, then try my suggestion.
hope it helps
Posted on Oct 08, 2008
Panasonic TX28DTM1 can see picture through a blue hayse on digital freeview The analogue picture is OK
So what is your problem it looks like a statement . Specify your problem clearly with necessary details .
And old is your tv and have you faced any problem or replaced any component recently .
post back these details
Oct 04, 2008 | Panasonic Televison & Video
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
I have built in Freeview in my Hannspree television. The picture has completely gone, and I have tried retuning, but to no avail. The message is 'database empty', but according to the operator at...
This tv is a flat LCD tv wright?Not a big bulge back CRT tube tv,If this is CRT tv is analoge design tv dosen't have freeview Digital Tuner inside of the tv.If it is a flat LCD tv.Make sure ur setting for retuning not on CALBE SETTING.Make sure ur tv setting are AIR SETTING and have good Digtial antena will get a stronger signal get all the free AIR broadcasting stantoins channels,a good strong Digital antenna design does make big a different.
Aug 04, 2011 | Hannspree (K206-10U1-005) Television
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like, buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Digital tv -analogue vcr records and time records and plays back only with the picture on. It will not record with picture on standby
Of course it won't record if the TV is in standby as there is no signal. If you wish to record TV programmes without having the TV switched on, you need a freeview or freesat box for your Video Recorder.
Hope this helps.
Nov 15, 2010 | Hitachi C21FL20F TV
Resetting a sony television to receive digital programs
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
Jul 26, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
