Question about Hunter 20537 / 20538 The Vista Iron Ceiling Fan
Hunter ceiling fan: how to open the canopy to replace remote receiver
My Hunter ceiling fan is model 20537, but this applies to many other Hunter fan models. When trying to open the canopy to replace the remote control receiver unit, I could not easily open the canopy. It had no visible screws or clips. It had an upper plastic ring, so the apparent solution was to twist it left or right in a circular motion. This did not work either. I could not find the installtion booklet, and was not able to find the information in my internet searches. At long last I learned how to open the canopy, and am posting my own solution here.
  • DIYrevolvo Oct 08, 2008
    To open the canopy at the ceiling, which houses the wiring and the remote control receiver, you first must remove the smooth upper plastic ring. The way to do this may not necessarily be intuitive. You must squeeze the plastic ring inward to allow it to clear two small internal clips that hold it up. But this only works in one direction, so it may take a number of tries to find which direction to squeeze inward. Once the ring slides down the canopy drops, and there are 2 screws that hold this model fan up to the shallow steel box attached to the ceiling. Be aware that removing these 2 screws will permit the weight of the entire fan to be released downward. This fan is hinged on 2 small metal tabs, so removing the screws will not cause the fan to fall, but only to swing down on one side.
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 5581 Answers
SOURCE: I have a hunter ceiling fan (model #20537) which
Check with stores that sold it and see if they will warranty replacement. I think there is a lifetime warranty, thats why you pay the big bucks for the Hunter name.
Posted on Aug 02, 2009
SOURCE: Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Posted on Aug 21, 2009
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
SOURCE: I have a Hunter Ceiling Fan Model # 23529. The
The receiver part #8511204000 and runs like $50 plus shipping....if its the remote the replacement part# 23529-300 and it runs like $40 plus shipping. You can order it from Hunter or other Hunter dealers.
Posted on Sep 03, 2010
Where does the receiver go on a model 59016 hunter fan
It goes in the canopy cover at the ceiling. Slide into bracket.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Can't fit remote receiver into canopy of Hampton Bay ceiling fan.
Hang the fan and slip the receiver between the space above the hanging ball on the fan. Hunter remote might not work.
Mar 15, 2013 | Dryers
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I have a hunter ceiling fan and the light blew, when it blew then the remote quit working for the light, it still turns the fan on & off but after I replaced the bulb it still will not operate the...
Hello nita... I believe the fact that the remote stopped working is due to a weak battery in the remote. Change that battery and you should be back up and running. Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Hunter 20537 / 20538 The Vista Iron...
I have a hunter ceiling fan (model #20537) which makes noise at low speed. Sounds like ball bearings need oil. Any suggestions?
Aug 02, 2009 | Hunter 20537 / 20538 The Vista Iron...
Hunter ceiling fan remote control will not work
Are you talking about just activating the fan, or the tv as well? If you just need the fan, in the top plate where your fan is mounted into the ceiling, there is a box. This box has 4 switches that are turned on or off towards a number. You find that and then just open your remote up and set the switches in the remote to the identical numbers. I need help for the tv codes i lost the booklet, i need the codes for a daewoo.
Apr 26, 2009 | Hunter 20537 / 20538 The Vista Iron...
Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Apr 13, 2008 | Hunter Dryers
Hunter 20537 / 20538 The Vista Iron Ceiling Fan Logo
1,374 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
