Question about Sharp UX 510 Plain Paper Thermal transfer Fax
Receivers complain that the fax is light/unreadable
I receive faxes fine. However, every time I send one, the person calls and says that it cannot be read. I used the fax machine to make a copy and it came out unclear. Is there something that needs to be cleaned or changed?
Thank you
    Scholar:
  • 62 Answers
More than likely (since the problem is with sending and copying only) the mirrors inside the fax machine need cleaning. However, depending on what type of fax machine this is, this could be a pretty involved job. If you are pretty comfortable with taking covers off, you might try it, but if its a pretty expensive fax machine, I would call a professional.
hope this helps!!!
chad
Posted on Oct 08, 2008
Hp 8500 printer/fax machine will no longer receive a fax in color but can send in color. it used to work fine both ways. What can I do to fix the problem?
If the person who is sending the fax cant send in color, then you would not be able to receive the fax in color. Just make sure you choice the option to received the fax in color. Ask someone to send you a fax in color and just received in color.
Feb 17, 2013 | HP 8500 Premier All-In-One InkJet Printer
Faxes not coming in - what do I do?
i beleive you can send faxes right but cant receive them..are u using an answering machine..make sure that u set the ring of the fax two tones higher than the answering machine..and also make sure that that the auto answer is also on in your printer..also ensure that your telephone service does not provide voicemail service..otherwise all faxes will go to voice mail..it should have distictive ring pattern..thanks
Jan 28, 2010 | HP Officejet 4315 All-in-One Printer
When I send faxes the person receiving the fax is complaining that there is a solid black line appearing on the fax
hi there
it seems like there is some dirt or correction fluid on the scanner glass ,flip open the cover where the documents feed in you will see a glass ,clean this glass with a damp soft cloth this should solve the problem
Nov 19, 2009 | Brother FAX-2920 Plain Paper Laser
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Machine sends fine. Machine does not receive readable copy.
Is this connected to a computer? if so you can run head cleaning utility from the print driver properties. This will pump ink to the head and flush out the clogs. That is the easist way to make sure you don't have a head problem. If it is not connect to the PC then scroll thru the menu to see if there is a maintanence section and look for head cleaning.
Hope this Helps
TankMurdock
Apr 24, 2009 | HP 920 Plain Paper Fax
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Samsung SF 3200
The person you are sending to has a busy phone line.
Call your cell phone from the fax machine to test.
Oct 24, 2008 | Samsung SF-3200 Fax
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Print Size Changes
This maybe down to the other persons fax machine if your copy is coming out perfect try sending it to a different fax number to see what happens.
If the same thing happens press the menu key and you are looking for a heading call setup or machine settings within one of those will be TTI settings and make sure that reduction send is not on.
Hope this helps sorry a little vague but have manual at work
Thanks J
Nov 22, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
Sharp UX 510 Plain Paper Thermal transfer Fax Logo
234 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
