When the machine is involved in its cycle, any movement of the drum produces a rusty scrape noise, almost electric buzz like.However when the machine is switched off and the drum turned by hand no noise is apparent. Any idea, cheers
  • richikennedy Oct 09, 2008
    thanks for the suggestion, problem is i'm a bloke who doesn't wear a bra, i checked the carbon brushes and i think theyre the cause.
    President:
  • 1,462 Answers
Maybe a bra wire stuck between tub and drum
Posted on Oct 08, 2008
Machine fills, then on entering wash cycle makes loud grinding noise kinda like a dull hacksaw on rusty metal.
Does it make the sound when you turn the drum by hand? It could well be the drum bearings that have gone.
Aug 01, 2016 | Washing Machines
Lg dryer drum makes a scraping noise when turned on, what could it be?
The noise is caused by the drum support rollers that are faulty.
Please supply the machine model number.
Feb 13, 2016 | LG Dryers
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Amana electric dryer #NED5200TQ when i push star button all it does is make a buzzing noise no matter where the dial is
open door and turn drum clockwise by hand,listen for scraping"something hung in front or rear drum seal"close door and try start.if it still hums you may have a bad timer or motor ,or switch on motor.you may need to call for service on this one
Dec 10, 2013 | Amana NED5200TQ Electric Dryer
Washer gets noisy and bangs around or out of balance during spin cycle
OK, lets see if I can help you. First, remove the 2 screws that are on the rear of the top panel, slide the panel back about 1/2 inch and lift the top off. Look at the rear bearings and any other visible signs of malfunction. Also, be sure to check the suspension for anything that may be loose. Post your findings back to me.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Maytag MAH2400AWW 2.4 cu. ft. Compact...
When in spin cycle sounds like a large bolt is spinning around washer shakes spin cycle really fast scrapeing noise
The scraping noise is the grinding noise from the worn out ball bearings. Replace them. You can open the back cover by removing the screws. To fix new bearings remove the drum wheel & then the bearings. It is purely a mechanical job.
- sonsunny
Jul 09, 2011 | Washing Machines
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Hi, there i a knocking noise during the spin cycle on my hotpoint aquarius 6kg wma56 washing machine?? How do i fix it?
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Nov 12, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Dryer makin scraping noises
You need the drum wheels and/or the wear pads replaced. If you continue like this, you will make more damage and the cost will be greater. Repair it while your at the warning stage. This involves completely opening the unit and removing the drum. If not up to it, call an expert. goodluck, Macgivor
Oct 11, 2009 | Hotpoint TDL14 Electric Dryer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
