Question about HP Office Equipment & Supplies
I have a HP Laser Jet 4000N sitting here in my office that makes a noise like the gears need oiled or some ****. Happen to know what I could use to help get them doing? When pulling a page from Tray 2; the bottom roller doesn't push it through, and from looking at it, I'd say it's because the top roller isn't spinning the bottom well enough.
  • 34 Answers
Thats true about the rollers, but the HP 4000 "groan" is common.
Remove the pickup roller from the paper tray. Right behind it on the same shaft is a TORQUE LIMITER. Go ahead and remove that. Now Replace the roller to EXACTLY where it was, you will find the detant position. (dont go too far as the tork limiter is not there now) Print a page.... Does the noise stop? If so all you need is a torque limiter, and you can even fix your own limiter. EASY.
Posted on Mar 12, 2009
  • HP Master
  • 4,338 Answers
This happens when the rubber on the roller is worn or has accumulated paper dust on it. The rubber is of a blue or grey color. Usually you can clean the gear with cotton swab and alcohol.
Also, there is a roller in the paper tray and a rubber pad that can be cleaned with alcohol.
If it is badly worn, you can order a replacement. There is a maintenance kit available which contains a fuser,transfer gear and up to six rollers. I keep one kit handy to keep my HP in top form.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 08, 2008
Hp laser jet 4 plus gear noise
That gear is called the "fixing coupler gear" and is part number RF5-0350. You can get them here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_48&products_id=125
Jan 02, 2012 | HP LaserJet 4 plus Printer
RG5-0457-000CN LJ4
RG5-0876-050CN LJ4+/5
Drive Gear ***'y
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Aug 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp color laser jet 2600n printer making loud griding noise when yu power up & print. It prints OK just very noisey
It could be the roller gears. They're a relitavely cheap material and break pretty easy. We had a HP 2500 and we had the same problem; got an expert opinion and thats what he passed. It should be around $30 replacement plus expert fees. So with that being said, as long as it prints ok you're fine. Open it up and check to see if there are any visable factors causing this to happen. Keep an eye out for the next few days to see if anything gets too warm; unplug it if it is just to let it cool, plug it in again and if it happens again you may need to purchase a new one.
Good luck and please rate my solution accordingly.
V/r,
Don
Jan 25, 2010 | HP Color LaserJet 2600n Printer
My HP color Laser Jet 3000/3600/3800 is sqeaking
You need to clean the carriage ride path for the cartridge.
Aug 12, 2009 | Office Equipment & Supplies
Noise in the Laser Jet 1022 Printer
try and check for broken gear- tooth on one of the sides of the machine
May 29, 2009 | HP LaserJet 1022 Printer
Hp 4600 noise problem
when power on the main board do initial devices:
1) the cartridge include toner unit and photo drum unit
2) fuser unit and all paper road include motors and sensors through the paper road.
the noise at power on you may check:
1) the toner unit that maybe over life cycle to mak much more obstruction, you may take out the cartridge and turn the gears if felling very hard so need to change the cartridge.
2) the toner unit gears damage a little that could make noise, you may check all gears on the cartridge. attention other side drive gears.
3) check the fuser unit gears do same thing above.
hope you fix it and feedback the result thanks
May 06, 2009 | HP LaserJet 4600dn Color Printer
Insatallation of HP Laser Jet 1020 Printer A Toshiba Laptop with Vista Window Office
CD you are taking about drive to install did you know you can instal from safe mode try it and if no work come back here
Jul 14, 2008 | Toshiba Satellite A135-S4527 Notebook
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
