Question about Compaq Armada M700 Notebook
Crazy Mouse My main mouse is a wee blue button in the keyboard, it goes where it likes I have no control. It does up and down fine but sideways it just carries on to the edge of the screen. I have been using a plug in mouse but that is still dragging to the right of the screen.I give it a good shake and it works like normal for a few minutes. It is making the laptop immpossible to use, and I have no clue what it could be!
  • Kenneth Hall May 11, 2010
    your laptop has one of those small blue like foam buttens in the center on the keyboard.. does it have a touch pad? the blue butter isnt really a mouse. its to stop the screen from getting smashed. yes it controls the mouse thats cus when its pushed down it stops the mouse conrtols. kinda like a key lock on your phone.
    Master:
  • 788 Answers
The j-mouse switch is faulty or dirty. The best thing you could do to solve this is replace the keyboard on the laptop. The HP Parts Store should have replacement keyboards that you could order or search on eBay.
Posted on Oct 08, 2008
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
Mouse buttons spontaneously click themselves
I'm afraid that keyboards and mice don't like tea much at all. You can pick up keyboards and mice cheap enough and to be honest they are just not worth repairing. Even a tin of Servisol Video 40, which you can spray on the contacts to clean them will cost you as much as a mouse would!
Mar 12, 2017 | Logitech Cordless Mice 910001822 M510...
Mouse wheel jumps around like crazy even when i click it as a button
your mouse speed is way to high turn your mouse speed down half way in your utilitys.
Jan 25, 2011 | OCZ Mouse
Logitech Wireless mouse.
As a rule the mouse is matched to the keyboard and a new mouse probably wouldn't work with the receiver.
Try this:
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 20, 2008 | Logitech Cordless Mouse
Optical mouse moves by itself
yes reinstall the software
Aug 31, 2008 | Computers & Internet
My keyboard and mouse
Underneath the keyboard there should be a series of number . this should be the id.
let me know if this helps.
May 08, 2008 | Computers & Internet
My new Nexxtech NWOMMI cordless mouse is not working
Here is what I found about the Nexxtech Notebook Wireless Mouse (NWOMMI):
1. The 2 AAA batteries must be inserted correctly. Look carefully at the "+" and "-" marking on top of the battery compartment and put your batteries in accordingly. Otherwise the mouse will not work, and could be damaged. After the batteries are inserted, the red light at the bottom of the mouse should come on. More on batteries below.
2. Insert the USB receiver into a USB port. The blue light should come on. Press the little button next to the blue light and the light should start to blink,
3. Whild the blue light is blinking, press the connect button at the bottom of the mouse. It is the big black dot inside the white label. Check that the blue light on the receiver is blinking faster, and then change to a steady light.
4. Now check the function of the mouse by moving it on a texture surface.
5. If all goes well, your mouse should be working.
However, here is the bad news. Either due to bad design or some flaw in manufacturing, the mouse consume batteries like crazy. I used fully charge NiMH AAA batteries and they last for only a few hours! And the worst part is that, I checked the batteries when the mouse stop working, ONE of the batteries is COMPLETELY drained, in fact it registered a reverse voltage of -0.1 volts (a charged values is +1.2 volts). This is definitely engineering problem. Note that even when the batteries are in this state, the red light may still come on, and sometimes the re-connection seems to be ok (i.e. the blue light blink faster and then changed to steady). However, the cursor will not work when you move the mouse! Recharging the batteries and the mouse will work again.
Based on the above observation, the mouse instead of having a power-saving feature, it actually has a power-wasting feature!!!
Nov 12, 2007 | NexxTech NWOMMI Mouse
Logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Oct 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Compaq Armada M700 Notebook Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
