Question about E-Machines eMachines Desktop PC
Fans and lights come on but the harddrive and cd bays do nothing
I'm working on an Emachines T6524 I can get the lights to come on and the fans also but the harddrive and cd roms don't seem to be getting power, I have replaced the power supply cause originally it wasn't doing anything, I cleaned under the fan for the processor and got some juice but now I'm stumped as to what is going on with the hd, cd roms. Any help you can give is appreciated. thank you and have a great day
  • Jerry Dougherty
    Jerry Dougherty Oct 08, 2008
    that is what im afraid of ill look into that now, thank you
    Master:
  • 788 Answers
If you replaced the power supply did you plug it into the drives. If so then your motherboard is most likely faulty.
Posted on Oct 08, 2008
My T6524 PC will not shut down when I hit the button.
Please check following KB article:
Advanced troubleshooting for shutdown problems in Windows XP
http://support.microsoft.com/kb/308029
Sep 13, 2011 | eMachines T6524 PC Desktop
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Feb 22, 2011 | eMachines T6524 PC Desktop
I have a t6524 running xp media center sp3..everything inside is stock. The problem is sometimes when i try to turn it on the fans run full speed and the the hd status light comes on for about 15 seconds...
Remove the video card and connect the monitor to the onboard VGA. If the problem continues, check the power supply. If you have another with the same wattage rating, see if it works ok - it might be the power supply going out.
Oct 31, 2010 | E-Machines T6524 PC Desktop
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
My niece just called and her emachines w3507 doesn't boot,the light on the front lights and a fan comes on a little louder than normal but nothing else happens,no harddrive light or noise ,screen says no...
start ur computer press F8 rapidly if popup menu came then goto safe mode,if not then u have a problem in ur ram.but u say its giving no signal thats mean vga resolution may be not compatable with ur monitor.go to safe mode and remove ur vga driver and restart ur pc if u have a vga problem.
still u facing a problem then better chage ur ram
Mar 06, 2010 | eMachines W3507 PC Desktop
The computer powers on-the fans work,dvd bay opens but there is nothing on the screen. I removed the hard drive and checked it Had another computer same model and mother board and it boots. checked all...
Sometimes the CD or DVD going bad will keep it from booting.
I'd disconnect them and try a boot. Just might work and you'll save yourself the cost of a new motherboard.
Another thing to try is swapping out memory.
Feb 22, 2010 | E-Machines eMachines Desktop PC
I ahve an emachine T6524 and when you start it up the hard drive light comes on yellow and the cpu keeps beeping. It never seems to boot up. Nothing appears on the screen
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
May 09, 2009 | E-Machines T6524 PC Desktop
Emachines d3315 video failed - no signal to monitor.
Is the system work using the old video card? if yes then, use it and then reconfigure the in the bios setup using the PCI video card. You can insert it simultaneously and then use first the old video in preparation for the configuration using the new PCI video card
melnavz
Feb 12, 2009 | eMachines T6524 PC Desktop
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
Feb 05, 2009 | eMachines T6524 PC Desktop
Updating my T6524
If the device is working, why update? What R U trying to fix?
Jun 09, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
