Question about Acer TravelMate 3260-4874 Notebook
Acar 3260 headphone socket no output
You suggest checking line out pin on motherboard - howdo I do this ? But if this is 'inside the laptop then it is not the solution.I have had output from the headphone socket and now I don't. It is a software related problem I think
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
My travelmate3260 DC POWER JAck pin is pulled from
The power socket needs to be replaced, but it requires the laptop to be completely dismantled to get access to the power socket on the motherboard. I suggest you get a quote for this repair.
Sep 29, 2009 | Acer TravelMate 3260-4853 Notebook
Acer3260 headphone no output
has a problem with the sound card because there is no audio or can be a cold solder point
Aug 22, 2009 | Acer TravelMate 3260-4874 Notebook
Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Sony VAIO® VGN-N130G/B PC Notebook
I am trying to connect my Acer Aspire 5552 WxMi Laptop to output its Audio to my LG LCD TV monitor by using dual RCA to 3.5 mm headphone plug. But even after connecting the rca-to-headphone plug properly I...
Have you got the TV set to the correct channel ? A lot of the TV's have a PC input, but no sound when that input is selected, so plugging the audio into another input won't allow you to use it as a monitor and have sound at the same time. If it were a desktop PC, you could use a DVI-HDMI convertor and get the sound in that way, but most, if not all, laptops have analogue 15 pin video outputs.
Jul 20, 2008 | Acer Computers & Internet
Jack for headphones
Whether your unit has a jack for headphone or not I don't know. But if it has sockets for line out it can be of some help. Line out sockets provide the output from preamplifier section and in many conventional audio systems the same is the substitute for driving headphones. So you can try connecting your headphones to the line out sockets using an adaptor pin.
NB-The preamplifier of all audio systems are not able to drive headphones. Only some can. But if you introduce a headphone amplifier between the line out sockets and your headphone it will SURELY work.
Jan 29, 2008 | Oritron OP1181 CD Boombox
Head phone is not picked up the sound
check your line out pin thts a problem i think this is motherboard problem
Oct 31, 2007 | Acer TravelMate 3260-4874 Notebook
No Audio Output on headphone.
uninstall audio diver and
reinstall your audio driver
i think thisis motherboard line out problem
check external speaker its is work mothwrboard is not problem
Oct 21, 2007 | Acer TravelMate 3260-4874 Notebook
Acer TravelMate 3260-4874 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
