Question about Kenmore 22422 Top Load Washer
Kenmore 22931 Top Load Washer
The water is in 2 small streams when filling the tub for the rinse cycle. It takes a LONG time to fill before spinning.
  • 958 Answers
Could be a clogged filter in the inlet valve. remove the hose. make sure you have pressure from your faucet. inspect the inlet valve where you connect your hoses.
they have plastic filter inside.
inspect them and clean them, they could be blocked with dirt.
tnx 4 using fixya,
drcool
Posted on Oct 08, 2008
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
