Question about Dryers
Hotpoint CTD 40 - Dryers
  • neillilley Oct 09, 2008
    where is the reset switch for thermostat?
  • AlmostBob
    AlmostBob May 11, 2010
    and the problem is?
  • 550 Answers
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Posted on Oct 29, 2008
  • wallycarl86774
    wallycarl86774 Apr 03, 2016
    hi on ctd40 you can reset thermistor if you take heater cover off there are two small screws hold healer in cover take them out be gentle with heater there very fragile you will see three components on top with wires normaly a black one has a small hole in top use a needle push it down hole not to hard it will reset it if u look at bottom it will be concave meaning looks bent inward when reset will curve outwards remember to pull plug before you start
  • 750 Answers
Hotpoint CTD 40
And you need ????
Or the problem is?????????
Posted on Oct 08, 2008
  • Neil Golan
    Neil Golan Oct 09, 2008
    Hotpoint CTD 40 , is not the model number!
    You cand find the model number when you open the dryer door, it is on a label around the door jam or opening to the dryer!
    waiting your responce!
    Huuum
  • Neil Golan
    Until I hear from you with the model number , you can first try to reset the system.
    Try by unplugingthe dryer for 5 minutes and then restarting it!
    if you can not reach the plug, you can throw the circuit breaker off.
    Let me know if this works. waiting for your model
    huuum
Remove the top of a hotpoint ctd 40
usely 2 or 3 screws in back of lid
Jan 11, 2015 | Hotpoint Washing Machines
Hotpoint condenser dryer ctd 40g very noisy took black fan off and can hear something loose inside
something stuck in the blower housing? pull out off cabinet and u got a view
Nov 29, 2014 | Dryers
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
Snapped belt
are belts that snap
Feb 21, 2010 | Dryers
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Runs slow then speefds up
If it is slow in starting, could be faulty start capacitor, slack or worn belt,overloading of course.
the capacitor is mounted near the motor, and is a round cylindrical tube about 4" long.
If u require any more info , then let me know.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Help
stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Aug 07, 2008 | Dryers
Dryers Logo
227 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
