Question about Toshiba Satellite A75-S226 Notebook
How do I physically remove old hard drive for bigger new hard drive?
There are several plates on the bottom of my lap top that are held in place with small screws. Where is the hard drive on this lap top and how can I remove it?
Thank you,
Hersch
    Master:
  • 538 Answers
It is on the end..with two or three screws holding it down..be careful..
Posted on Oct 09, 2008
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
Display
Physically mechanically broken?
If your display was physically intact when you brought your laptop and up on receiving it was physically broken then it is their liability and apparently have caused the damage so they need to fix it for you!
Sep 28, 2017 | Toshiba Satellite 4030CDS Notebook
How to remove hardrive from ml3109
Turn the laptop so the bottom is facing up. Make sure you have powered the laptop off and have unplugged the AC adapter and battery. Near the part labeled E there are two small phillips screws. You would need to remove those and the tray at location E will pull out with the hard drive attached. There will be 4 screws(two on each side) holding the hard drive onto the tray, remove those and the hard drive can now be taken out. Reverse the steps using the new hard drive.
Mar 05, 2011 | Gateway Computers & Internet
I just purchased an 2.5" hard drive for my lap top and after removing the old hard drive, I noticed the pins in the hitachi are set differently than on my old hard drive. Old hard drive has two rolls of...
it may be in a hard drive holder so check the laptop manual or web site to see for yourself if its just a hard drive case with a regular drive inside
or it may be a newer SATA driv in that case you have the wrong type
Aug 07, 2010 | Computers & Internet
I HAVE A HP DV6700 LAP TOP HOW DO YOU CHANGE THE HARD DRIVE
The official service guide:
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Nov 13, 2009 | Computers & Internet
How do I read a hard drive taken from a WD Media
go into control panel click on administration tools storage there you can initialise and format
Jul 30, 2009 | Western Digital Media Center WDXF1600JB...
I want to fit bigger hard drive to my ibm 380ed
Hard Drive Installation Instructions:
  • 1. Turn the notebook upside-down.
  • 2. Remove the battery pack.
  • 3. Remove the 8 Phillips screws on the bottom half of the notebook.
  • 4. Turn the notebook right-side-up.
  • 5. Raise the LCD.
  • 6. Remove the top half completely off of the notebook. Remove the 3 keyboard cables from the motherboard and set the top half of the notebook aside.
  • 7. Remove the top Phillips screw from behind the LCD right hinge.
  • 8. Remove the Phillips screw that is located above the parallel port.
  • 9. Remove the CD/Floppy disk and flip it out of the way (you don't have to remove its cables).
  • 10. Slide the hard drive out of the notebook.
  • 11. Remove the bracket from the old hard drive and install it onto the new hard drive.
  • 12. Slide the new hard drive into the notebook, making sure that it is firmly connected.
  • 13. Place the CD/Floppy disk back.
  • 14. Place back the Phillips screws that were removed in STEP# 9 and STEP# 8.
  • 15. Take the top half of the notebook and place back its 3 keybaord cables to the motherboard.
  • 16. Snap the top half of the notebook down and make sure that it is firmly in place.
  • 17. Close the LCD.
  • 18. Turn the notebook upside-down.
  • 19. Place back the 8 Phillips screws that were removed in STEP# 3.
  • 20. Place the battery pack back.
  • Enjoy!
    Jan 19, 2009 | IBM ThinkPad 380ED
    How do i fix a hard drive on a lap-top
    You need to remove the old hard drive first. Depending on your model, there should be a screw or two on the bottom of the computer that gives you access to the hard drive. You remove the old drive, take it out of it's caddy, take the special connector off of it and install it on the new drive, put the new drive in its caddy, and replace the hard drive.
    Thanks and please take a moment to rate this as fixya.
    Jul 06, 2008 | Gateway Computers & Internet
    Memory
    To get at some parts takes some doing, but the AVERATEC 4200 AV4265-EH1 is user upgradable. The 80GB hard drive and one of the 256MB memory slots sit under a large bottom panel held in place by seven small screws. Removing two additional screws frees the hard drive. To reach the second RAM slot, you have to loosen one additional screw (labeled "D" in the manual but not on the notebook) inside the bottom compartment, pop out keyboard's four top latches, and lift it off. The RAM slot, the only exposed component beneath the keyboard, is easy to find. Another 256mb run both will surfice.
    Sep 22, 2007 | Averatec 4200 Notebook
    Toshiba Satellite A75-S226 Notebook Logo
    103 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
