Question about Philips Televison & Video
2004 philips 60 ''projection screen hdtv model # 60pp9202/17f
The tv will not come on. If you unplug the tv, and plug it back in some times
it will come. When the tv doesnt come on, the ON button flashes 9 times. Some times it take days,weeks, or even months before the tv comes on.
A SIX PACK AND A SLEDGE HAMMER
Posted on Oct 16, 2008
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
No power. Is there a fuse?
Just unplug the tv for ten minutes and then plug it back in.
Dec 06, 2009 | Philips 60PP9202 60" Rear Projection...
TV won't do anything. There are no lights when
Unplug the tv off for ten minutes and plug back in. Then turn on
Nov 04, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
