Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Kenmore oven door stuck closed
I have a kenmore gas stove-model #790.75715890 / serial #VF81210635.
I was attempting to have the oven self clean. Then I hit clear now the
oven door is stuck closed.
  • Anonymous Oct 22, 2008
    1. my Kenmore 790 gas oven door will not close.the clean button was accidentally pushed after broiling, and the door open.I pushed clear-nothing,unpluged the cord-nothing. what can i do?
    Scholar:
  • 131 Answers
If you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Posted on Nov 19, 2008
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
After self cleaning cycle, oven door will not open. the lever won't move.
in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
all too common with self clean ranges.
unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
i see this at least once per week
Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
Stove has locked down /frozen
turn off the circut breaker for the stove. I JUST had to do this myself.
Jan 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
182 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
