Question about NorStar Meridian M7310 Phone
Handsfree how do you turn the handsfree feature on (m7310)?
  • edk73 Oct 22, 2008
    Hands free mute button stopped working and became the intercom while the intercom button comes up with "forward to" How do I get this back to the way it was?
Your system admin usually sets this. IN adminstrative programming
Under terminals and sets
capabilities
Handsfree can be set to std, auto or none.
Posted on Oct 23, 2008
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
My Norstar M7310 is stuck in handsfree mode. Is there a feature or programming fix for it?
Nothing in programming typically would help with exception to maybe swap by plugging in a M7208 into your problem jack then swap back to m7310 again. Going to 08 and back to 10 can sometime clears issues otherwise sounds like a bad phone and needs repair.
Oct 03, 2012 | NorStar M7310 Corded Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
Does auto answer feature is available on Norstar phones? if yes, how?. Thanks!
Yes in system programming, handsfree answer back must be enabled. There are several different phone system models that the M7310 phone works on. I need the model number of the phone system to give accurate programming directions.
Dec 07, 2010 | NorStar M7310 Corded Phone
I am wondering how to intercom to another phone extension. I mean, where you call that room and can talk to them w/o them having to pick up the phone extension.
Providing that the handsfree answerback is turned on on the set your calling,you can use Voice call (feature 66) and the intercom of the person your calling.
Aug 12, 2010 | NorStar Meridian M7310 Phone
When I hit handsfree button it says it is muted cant figure out how to un-mute the phone
If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
Jul 04, 2010 | NorStar Meridian M7310 Phone
I have a Norstar Meridian with M7310 phones. When calling out using the speakerphone, the microphone doesn't work. When trying to switch to hands-free during a call, it puts the line on hold.
sounds like your telephones not programmed for handsfree.
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Sep 14, 2009 | NorStar Meridian M7310 Phone
I have an m7310 phone and when I try to use the phone hands free, the speak does not work. The speaker does work for feature 86 which is music. How do i fix this. I believe it is some sort of...
You need to go into the system's configuration enter the phone extension go to phone functionnality and at the prompt automatic handsfree put yes
Aug 01, 2009 | NorStar M7310 Phone
How do I voice call another extension and use handsfree overthere
Try Feature 66 and the extension.
If you want to program this feature on your set, find an empty button (feature * 0 and press the keys to see what is on those keys)
Feature * 3
press the button that you want to program
Feature 66
this will program the button for Voice Call.
May 28, 2009 | NorStar Meridian M7310 Phone
Problem with Speakerphone
It is maybe some setting called Handsfree. On the phones that work, press Feature *0 and press the buttons on the right from the bottom up. The very bottom button should be handsfree/mute and the next one or two Intercom xx(x). Now check the ones that don't work and see if they read the same. I'm guessing not.
It takes system admin access to turn on handsfree per set. Check with your telephone system manager or installer for the programming.
Carl
Jan 09, 2009 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
928 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
