Question about SanDisk Sansa Clip MP3 Player
Won't fully charge on a belkin mp3 player ac adapter?
  • Dan Sal
    Dan Sal Oct 16, 2008
    In my case my battery powered little USB charger only works sometimes, when I'm lucky, Often if I ever unplug the charger and try to plug it in, the Clip won't recognize it. Also for some strange reason that also causes my battery powered charger to continuously discharge until my batteries are dead, that might just be a problem with my charger.
  • 8,596 Answers
Call Sansa and order the proprietary chargers for this device, unless you want to ruin your player.
Posted on Jan 01, 2009
My coby 705 is very fast to low battery what even if it is fully charge, what should i do?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 09, 2011 | Coby MP-705 Digital Media Player
What could be the problem if my iPod Classic won't charge?
Be sure to connect the charging/sync cable directly to the computer, not a USB hub. Most hubs are don't provide enough power to the usb ports to charge the ipod. If you need a method of charging the ipod while away from the computer connect your sync cable to a device like these: Even the USB port on Apple keyboards is not able to charge the Ipod.
If you're using the computer to charge the Ipod, be sure it stays on, when computers go into sleep or standby modes they stop charging your ipod. You may want to use one of the options below to charge your Ipod when the computer is off or in a different location than the Ipod.
For use inside: Best prices for a Belkin brand power adapter for Ipod click here
For use in the car: Best prices for a Belkin brand car power adapter for Ipod click here
May 10, 2011 | Apple iPod classic MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
I was charging my transcend ploayer through computer . i removed the data cable and it got off.. now its not turning on
Sometimes small devices dont charge fully while attached to a pc. Try attaching the ac adapter for the wall, and let it get a good multi-hour charge.
After letting it complete charging, attempt to turn it on as normal.
Hope this helps!
Feb 23, 2011 | Transcend T.sonic 610 MP3 Player
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
Will my Belkin ITE Power supply Model No.AC08 ET19941 LPS be safe/effective for charging my iPod Classic? This is an AC wall charger with USB connector presumably ok for the iPOD or other USB powered...
Yes as long as the wattage voltage etc... align between the device and the max output of the adapter you should be just fine in this particular case. I have the same adapter and I can not even remember what it initially came with but it has been so handy that I will keep it as long as it lasts. ;)
Jun 17, 2009 | Belkin Audio Players & Recorders
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery wont charge with an AC adaptor
Dear Verona,
Sandisk is a brand that is best used with its own. There are two degrees of separation here. 1) It is a cell phone charger
2) The charger is not in its family.
With both things working against the machine, it is not a surprise it will not fully charge.
Happy Surfing!
Feb 07, 2008 | SanDisk Sansa Clip MP3 Player
How do I charge the philips mp3 player?
Connect the supplied AC/DC adapter/charger to the 5V DC jack on your hdd and the power supply. The AC power icon will indicate on display showing that the Jukebox is now adapter operated. It takes 4 hours to fully recharge the hdd and once the battery is recharged fully, the jukebox can play up to 10 hours of music on the move
Dec 30, 2007 | Philips HDD120 MP3 Player
Creative zen touch
do you have an ac adapter? battery might just need to be fully charged.
Nov 09, 2007 | Creative Labs Zen Touch MP3 Player
SanDisk Sansa Clip MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
